Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 15th July 2007, 09:23 PM   #1
rdf is online now rdf
rdf's Avatar
Default High Voltage, Low HF Impedance Electrolytics
Apologies if this has been covered to death, searches on such common terms result in a flood of irrelevant posts. I'm rebuilding/hacking a Scott LT-110B tube tuner and replacing the ancient can caps with modern upgrades located directly adjacent their respective loads. So far the only electro's listed as low impedance, high frequency and rated at 250 VDC or greater found are the Rubycon YXF and Nichicon PS/PJ series. Only Nichicon supplies high frequency impedance numbers. Any other recommendations? Thx in advance.
"My loony bun is fine Benny Lava!"
Old 15th July 2007, 10:03 PM   #2
Juergen Knoop's Avatar
like this?
http://www.vishay.com/docs/28342/058059pl.pdf
probably a lot of manufacturers build low esr stuff
regards
Old 15th July 2007, 11:38 PM   #3
rdf's Avatar
Thanks juergenk. Yep, like that. Almost all manufacturers make low ESR electro's, few do 250 VDC and above and fewer still provide full specifications like Vishay. I'll take a closer look at their line, more recommendations still welcome and appreciated.
Thread Tools
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 08:49 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
Aleph-X builders LOOK!! HIGH-capacity (real!) electrolytics for sale Peter Daniel Swap Meet 5 20th February 2004 10:45 AM
WTB: Big high voltage electrolytics antness Swap Meet 4 25th November 2003 04:33 PM
Page generated in 0.11908889 seconds (73.03% PHP - 26.97% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
