diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Remote volume control for existing remote? (http://www.diyaudio.com/forums/parts/105243-remote-volume-control-existing-remote.html)
theAnonymous1 14th July 2007 07:59 PM
I have a HTPC with a remote and I would like to use this remote to control a motorized pot.:confused:
I don't need anything fancy, I just need to be able to control the motor on the pot; nothing else. I have no experience with PICs or IR signals.
Are there any remote volume kits that anyone knows of that have a "learning" function? If not, I assume the next step would be to decode the IR signal, but how?
:xeye:
thomaseliot 18th July 2007 10:28 PM
Take a look at Remote 1
http://electronics.dantimax.dk/Kits/...rds/index.html
theAnonymous1 19th July 2007 02:22 PM
Yes, I've looked at that site before. The problem is that kit comes with a PIC already programmed for specific IR codes.
To get it to work I guess I would need to reprogram the PIC with the IR codes from my remote. The problem with that is I don't know how to get the IR codes for my remote and I don't know anything about programming PICs.
I already own a controller that has a programmed PIC. I even have the source code. I still have no clue how to find out the IR codes for my remote or if it's even possible to use it with this controller. Then there is the other problem of not knowing anything about PICs and not owning a programmer.:xeye:
http://www.altronics.com.au/index.as...=item&id=K5026
jbateman 19th July 2007 02:42 PM
This place has devices for decoding IR streams, but you might have to program your remote for "SONY" on the volume button.
http://www.rentron.com/PicBasic/RemoteControl.htm
Look at the devices on the right side of the page.
Then you need something to drive the motor on the pot, like this.
http://www.robotroom.com/HBridge.html
jbateman 19th July 2007 03:14 PM
Actually with this thing and the motor control you're almost there:
http://www.ramseyelectronics.com/cgi...tion&key=MK161
http://www.ramseyelectronics.com/ima...pics/MK161.gif
theAnonymous1 19th July 2007 04:03 PM
jbateman you rock!!!!
I don't even need a motor control with this board. I can make it work with a +-6v supply. If I connect the ground point of the supply to one of the motors terminals I can use the + and - on each of the relays. Then I can connect the output of each relay to the other terminal of the motor. Depending on which relay is active it will either send +6v or -6v to the motor.
Brilliant AND easy!!!! Thank you sir!:D
ivan-UTN-ARG 4th August 2007 02:57 AM
hello...
does anybody have the schematics and programs...y need something similar...
if it's posible with tree channels
stepheno 6th August 2007 08:22 AM
Remote volume control and 4 channel selector
I need a remote volume control and remote 4 channel selector, with a mute and ON/OFF function for my Class D Amplifier. Is anyone aware if it can be bought as a kit? If not, does anyone have a circuit diagram? I do not want to waste time designing my own circuit.
Thank you.
Copyright 1999-2017 diyAudio
