Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th July 2007, 08:53 PM   #1
packer is offline packer  United Kingdom
Default Help in identifying ST OP AMP
Hi All,
I have op amps in a circuit marked C934 With the ST Logo
They are in a 8 pin SMD package.
I have tried ST microelectronics website and the usual searches but no avail.
I am desperate for this info, Thanks in advance to all that can help
Old 7th July 2007, 09:26 PM   #2
Gold_xyz's Avatar
Maybe ....
TS934 rail to rail amp-op ST
MAX934 comparator MAXIM
LMV934 RRIO amp-op NATIONAL
PC934 optocoupler SHARP
MC934 ic MOTOROLA
perhaps a photo can help ...
My English originates from here
Old 7th July 2007, 10:04 PM   #3
Thanks very much for the fast reply, But it's none of the ones you mentioned.
As to a photo it is only a "standard 8 pin surface mount Op Amp in a Bose Car Amplifier
These Op Amps are used as low pass audio filters for the 6 outputs of a Crystal Semiconductor CS4226 DSP processor
Old 8th July 2007, 10:21 PM   #4
Gold_xyz's Avatar
Hi
the C934 is very hard to find.
On the datasheet of DSP CS4226 suggest to use as amp-op
the MC34074 or MC33078
http://www.cirrus.com/en/pubs/proDat.../CS4226_F4.pdf
I sincerely think that the c934s can be replaced with many equivalent amp-op.
On pcb it is easy to see Supply Pin and I/O pin of old C934
(I think that this is a dual standard SMD amp-op)
bye
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 04:20 AM
Help identifying IC mtl777 Parts 4 17th May 2008 10:10 PM
Help identifying IC mtl777 Digital Source 2 16th May 2008 10:11 PM
Identifying a cap... EchoWars Parts 4 27th August 2006 11:43 PM
Identifying help placebo Full Range 0 31st July 2005 08:27 PM
Page generated in 0.07537 seconds (69.93% PHP - 30.07% MySQL) with 10 queries
