Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
is it okay to use an X1/X2 film cap in this circuit...
Old 6th July 2007, 11:28 AM   #1
jarthel is offline jarthel  Australia
Default is it okay to use an X1/X2 film cap in this circuit...
http://mitglied.lycos.de/Promitheus/delay.jpg
I'm looking to use the film cap in place of the .33uF 250V cap.
thank you for the reply
Old 6th July 2007, 11:44 AM   #2
smithy666 is offline smithy666  Australia
You should use an X1 or X2 rated cap for this circuit. BTW, this is from Elektor. I have used this successfully for years in an amp. If you are interested I have a PCB for this which also incorporates a remote power on circuit (you can use any switch to power on). Let me know if you want more info.
Old 6th July 2007, 11:53 AM   #3
quite interested. send me a mail.
Thank you
Old 6th July 2007, 12:03 PM   #4
drop me an e-mail @ atomicnirvana@gmail.com and I'll send you schematic + pcb layout
Old 6th July 2007, 12:03 PM   #5
is the cap value across the 2x 470Kohm important?
thanks again
Old 6th July 2007, 12:12 PM   #6
Yes, crucial. Its impedance is about 10k at 50Hz, which drops most of the mains voltage, effectively reducing it to around 24V (less the diode drop and small drop from the series resistor) to drive the relay coil.
Old 6th July 2007, 12:12 PM   #7
email sent.
thank you.
Old 6th July 2007, 12:16 PM   #8
so in the elektor circuit, a 24V relay is used?
thanks again
Old 6th July 2007, 12:19 PM   #9
Yes, it is a 24V relay. I've sent through the files to you
Old 6th July 2007, 12:23 PM   #10
can you tell me (or point me to guide) on how to calculate the resulting voltage by changing the value of the 330nF cap?
is it okay to use an X1/X2 film cap in this circuit...Hide this!Advertise here!
metal film or carbon film? Roushon Parts 36 17th October 2011 09:33 PM
Res Survey:....... Carbon film ...or... Metal Film ...............?? nina Chip Amps 13 14th April 2005 12:46 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Carbon film vs metal film resistors in a stepped attenuator? G Tubes / Valves 17 22nd August 2004 12:22 AM
Metal film resistors or carbon film in a tube amp? G Tubes / Valves 220 31st March 2003 01:57 PM
Copyright ©1999-2017 diyAudio
