| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
The impedance of the cap is determined by 1/(2*pi*f*c), where pi=3.141, f=50Hz and c=capacitance in farads (you need to divide the 0.33uf by 1000000). For 0.33uF, this produces an impedance of about 9.6k. Calculate the current drawn by the relay coil (24v coil divided by whatever the coil resistance is), then use ohms law to calculate the voltage drop across the cap. By changing the value of the cap it changes the impedance and hence changes the voltage drop for a given current.
#12 | |
I assume the 9.6K value is then paralleled to the 2x 470K to get the final resistance equivalent? why not just use resistance to drop the voltage? thanks again |
#13 | |
| metal film or carbon film? | Roushon | Parts | 36 | 17th October 2011 10:33 PM |
| Res Survey:....... Carbon film ...or... Metal Film ...............?? | nina | Chip Amps | 13 | 14th April 2005 01:46 AM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 11:13 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 01:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 02:57 PM |
| Page generated in 0.07323 seconds (71.22% PHP - 28.78% MySQL) with 10 queries |
