Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 6th July 2007, 03:09 PM   #1
Vogue is offline Vogue
Default Attenuator impedance?
Firstly sorry if the question is stupid ... but just starting my DIY hobby in electronics area. So please help me.
If you have a 10K attenuator, and ad to resistors of 250K one from input to output and one from output to ground, what vil the actual impedance of the attenuator with the resistors be - and how do I calculate this.
Vogue
Old 6th July 2007, 04:00 PM   #2
Steve Eddy's Avatar
You mean like this?
se
Old 6th July 2007, 04:32 PM   #3
AndrewT is offline AndrewT
whether the circuit is as SteveEddy has drawn or not, it would help if you told us the Zin (input impedance) of the next stage and also the Rs (source impedance) of the preceeding stage. These both affect the effectiveness of the attenuator.
If you can find out what capacitance is in the cables feeding in and out the attenuator and installed in the next stage input circuit, it would help?
regards Andrew T.
Old 6th July 2007, 05:12 PM   #4
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You can calculate it using Ohms law, however the Zin will vari when turning the pot.....
What's this circuit used for ???
Jan Dupont (formerly known as ACD)
B.Sc.EE
Personal audio website with free schematic and service manual downloads www.audio-circuit.dk
Old 6th July 2007, 06:31 PM   #5
First let's wait and verify that Steve Eddy's drawing is actually what is intended.
Second, to Vogue, instead of giving us a hypothetical circuit, why don't you tell us what you are trying to accomplish, then let us discuss possible solutions.
I'm wondering if you aren't trying to create your own constant impedance L-Pad?
If we assume the potentiometer in Steve's diagram is linear, that is 50% turn is 50% resistance, then when set to the top, instead of 10k ohms, the Output sees 9,615 ohms, when set to 50% the effective resistance is 4,902 ohms, when set all the way to the bottom, the output sees 0 (zero) ohms and the input sees 9,615 ohms.
Again, if we assume Steve's drawing is correct, and we assume that for some reason this is actually what you want to do.
Maybe you are asking simply as a point of curiousity, it that true, as others have said, it is simply a matter of Ohm's Law. However, if you are trying to accomplish something specific, tell us what that is, and I'm sure we can help you.
If you are trying to create an attenuator that presents a constant impedance, let us know. That's actually easy to explain and easy to obtain.
Steve (the other Steve)/BlueWizard
Old 6th July 2007, 06:49 PM   #6
Send a message via AIM to anechoic
>_in--250k----------->10kPOT_(wiper)---->250k---out_>
____GND____________GND______________GND
I think (but not sure) he means the R on the input is before the 10k pot
and the R on the output is after the 10k pot
both 250k's go to GND
see my lousy diagram above
Old 6th July 2007, 08:18 PM   #7
Well the idea is to improve the sound - if the resistors are good. I really dont understand why ... but the calculations match my own one.
The attenuator is going to be used in a DIY passive preamp - or in a modification of an old preamp I have. If used as modification, then I need to match the old values of the preamp's attenuator - on average ... but in my own project i can do what i like
Sorry not an expert ...
Vogue
Old 6th July 2007, 09:33 PM   #8
Sonusthree's Avatar
As Andrew has said, It would be helpful to know what the passive preamp will be between.
Output impedance of the source and input impedance of the power amp would be useful if available.
Martin
Old 6th July 2007, 11:12 PM   #9
Now you are beeing too practical ... My EAR899 amp does have some demands ... but however this was in some sence a theoretical question.
Vogue
Old 7th July 2007, 12:10 AM   #10
Sonusthree's Avatar
Vogue
Are you happy with the Ohms law explanation then or do you require further clarification?
Martin.
Thread Tools
stepped attenuator impedance troublecomes Chip Amps 7 9th January 2006 12:03 PM
Constant impedance relay-resistor logarithmic attenuator x-pro Pass Labs 75 27th June 2005 12:12 PM
BOSOZ--variable impedance volume attenuator jh6you Pass Labs 22 15th March 2005 09:34 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 09:35 PM
T-link attenuator with constant impedance peranders Parts 4 7th October 2003 01:19 PM
Page generated in 0.20144701 seconds (85.03% PHP - 14.97% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
