crazy remote control: candle
I_Forgot said:
I am more interested in how you discovered that a candle fixes the problem that in the problem itself. You are a mutant!
I_F
LOL, thanks I_Forgot. Actually, I got to thinking -- which is dangerous for a mutant -- it's infra red so maybe some heat will make a difference. So I lit a small scented candle, the kind in a tin, and put it about 6 inches in front of the sensor. It worked, even after I blew the candle out there was enough heat in the tin to keep it working until I moved the candle away. Moving it back got it working again until the tin cooled down.
I have changed the batteries twice, the last time with good tested batteries which work in another remote. I really don't think it's the handheld controller because I've taken it apart and cleaned it up, seems like it wouldn't work at all if it were bad, especially since the problem manifests itself after the amp has been on for about 20 minutes.
I should mention here the amp was the victim of a line surge when it belonged to the previous owner, she didn't want to fool with it when it quit working and she gave it to me. A zener diode was bad, which I replaced with one I had on hand and that got it to power up and work, which tickled me to death. But I'm wondering now if the same line surge might have fried the remote microprocessor, too.
