| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can anyone tell me if the following 2 transistors are interchangeable? 2SC2240GR 2SC2240BL or these 2? 2SA970GR 2SA970BL I can only find generic datasheets for 2SC2240 and 2SA970. If they have the same specs, what do the last 2 letters signify? Thanks, Neil |
#2 |
Hi Neil,
The suffix represents the beta (gain) range of the parts. If you look at the data sheets, somewhere you should see where they spec the gain ranges and you will see those letter codes. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#3 |
and due to the overlap in the ranges, devices from either range can have the same gain.
regards Andrew T. |
#4 |
Hi Andrew,
Very true, and expected. I suspect they test a few and label the entire batch. Therefore the gain range suffix is only probability (and also one reason I test everything before I use it). -Chris
#5 | |
High Vce, or high gain, or low noise would be three parameters that we users will tend to pay extra for. I guess this is what is done with the BC540 & BC550 families.
regards Andrew T. |
#6 |
For Toshiba small signal bjt that means (2SC1815)
O = hFE 70..140 Y = hFE 120..240 GR = hFE 200..400 BL = hFE 350..700 2SC2240 http://www.semicon.toshiba.co.jp/doc...eet_030325.pdf 2SA970 http://www.semicon.toshiba.co.jp/doc...eet_030324.pdf |
#7 |
Hi Gold_xyz,
What's nice is that they keep the gain range suffixes the same across transistor types too. -Chris
#8 |
Hi
Also I have wondered a many times if it is possible to change a bjt with a different gain. (same model) all perhaps depends on the circuit in which it works. A Idea is to select the bjt with a multimeter that can measure hFE and choose that with the nearest hFE. |
#9 |
Hi Gold_xyz,
In most circuits, probably. -Chris
#10 | |
Your multimeter won't tell you what current it has used to take the measurement. DMM hFE measurement is almost certainly based on constant base current. The meter then outputs the collector current as a gain value. This is rather different from the hFE vs Ic values given in the datasheet.
regards Andrew T. |
| 12AT7 vs 12AU7 (interchangeable?) | jn2630 | Tubes / Valves | 5 | 12th January 2008 05:34 AM |
| :Help: Are these transistors interchangeable? | tarnationsauce | Solid State | 22 | 14th August 2007 07:22 PM |
| Strange Variants of the T-Amp | EdT | Class D | 3 | 11th February 2007 11:07 PM |
| 6H30Pi variants | Jesse | Tubes / Valves | 22 | 9th April 2003 01:09 PM |
| tweeters interchangeable? | Craig | Multi-Way | 6 | 3rd December 2002 07:23 AM |
| Page generated in 0.09146 seconds (82.12% PHP - 17.88% MySQL) with 11 queries |
