| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 | |
regards Andrew T. |
#22 |
Chris,
Brief synopsis, The amp stopped working and although the red led on the front came on when it was turned on, the relay never clicked and it made no sound. I tried to diagnose the problem with a multimeter with the amp powered on and the power amp board loose. Yes.. very very stupid. I fried Q764, it actually burst into flame! I sought advice here and have eventualy bought replacements for all the transistors in the left channel, after Q705. I did this because the advice I got was that there was no easy way to know if any of them were damaged, and if they were they could cause the replcement transistors down stream to blow again. Please let me know if you have any thoughts on what may be damaged and need looking at. Incidentaly I found that R802 was blown and having replaced that, the relay clicks in and I get sound from the left channel. Q764, Q762 and Q752 are currently removed completely. When I turn on however, R764, Q760 and Q756 get very hot very quickly. Neil |
#23 |
Hi Neil,
You need to replace Q752, 754, 756, 758, 760, 762, 764 and check QN02 or just replace it. Also you need to test R758, 760, 762, 764, 768, 766, 764, RN02, 04. Have a good look at the traces and other parts in the area. Sounds like you had fun there! Replace the bias control with the same style part if you found Q752 damaged in any way. Test it if Q752 was okay. You also need some heat sink compound and the mica insulators for those transistors mounted on the heat sink. Good luck with your repair! -Chris
"Just because you can, doesn't mean you should" © my Wife |
| 12AT7 vs 12AU7 (interchangeable?) | jn2630 | Tubes / Valves | 5 | 12th January 2008 05:34 AM |
| :Help: Are these transistors interchangeable? | tarnationsauce | Solid State | 22 | 14th August 2007 07:22 PM |
| Strange Variants of the T-Amp | EdT | Class D | 3 | 11th February 2007 11:07 PM |
| 6H30Pi variants | Jesse | Tubes / Valves | 22 | 9th April 2003 01:09 PM |
| tweeters interchangeable? | Craig | Multi-Way | 6 | 3rd December 2002 07:23 AM |
| Page generated in 0.07406 seconds (74.26% PHP - 25.74% MySQL) with 11 queries |
