Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help with TT wiring into Hi-Fi console
Old 1st July 2007, 08:21 PM   #1
80sboy is offline 80sboy  United States
Default Help with TT wiring into Hi-Fi console
Ok - I have a zenith 60's console that I am placing a Dual 1219 into. I am having a problem with wiring. The old turntable was hardwired in, and I am trying to connect RCA adaptors, so i can remove the TT as needed. The wire coming from the stereo has a red/white, a wire wrap around it, and what appears to be a ground wire. I soldered the white and red wires into the tip of the rca connectors, but can not figure out what to do with either the ground or shield wires. When I connect the TT I do not get a signal coming though. I connected the TT to another stereo with a phono rca input and it plays great, so I know the problem is my wiring to the amp in the cabinet.
If I follow the wires to the amp, it appears that the "ground" wire is connected along with the red/white, but not the shielding. How do I connect the RCA plugs to work with the TT?
Make sense? Help!!!
Help with TT wiring into Hi-Fi consoleHide this!Advertise here!
GE Console RC 7100 A - need some help! j.english Tubes / Valves 22 3rd September 2008 11:57 AM
Crest 6A Console PSU imix500 Parts 0 19th April 2008 02:04 AM
Dynamix 20-4-2 console argonrepublic Instruments and Amps 6 2nd September 2005 07:16 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
old console cqboling Tubes / Valves 7 22nd May 2004 05:44 PM
Copyright ©1999-2017 diyAudio
