Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st July 2007, 10:50 AM   #1
jarthel is offline jarthel  Australia
Default computer grade elcaps
I was looking at the mouser catalog and found this. I read the datasheet and they are advertised as long life, high CV and current filtering (which I assumed meant the ripple current rating for this cap is high).
I got no idea what CV meant so some searching led me to believe it means the charge of the capacitor.
Anyway, that's not the reason for this thread.
As I said I was looking at mouser and they seemed to be more expensive than the snap-in that I was looking at.
Can someone tell me what is so special with computer grade caps? I compared the specs of a snap-in cap VS a CG cap (both from Cornell Dubilier) and the snap-in cap has longer rated life and the ripple current rating is higher.
maybe they are not special at all?
thank you for the reply
ps. I did search the forums but all I cannot discussions comparing computer grade caps with other type of elcaps. I also searched the net but all I can find is some history on the name "computer grade" caps. The rest of the search results are mostly shops selling these caps.
Old 3rd July 2007, 09:27 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
Honestly I don't know, but I think this is merely a term for cheap caps having quite ok quality.
Cheers, Hannes
Old 3rd July 2007, 09:41 AM   #3
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
BullS...
Looks like Sponge Bob has killed another thread.
Old 3rd July 2007, 10:58 AM   #4
AndrewT is online now AndrewT  Scotland
looks like we should ignore the names applied to cap types and instead read the specs for all models from each and every cap manufacturer.
regards Andrew T.
Old 3rd July 2007, 11:10 AM   #5
mzzj is offline mzzj  Finland
CV= capacitance per volume.
Old 3rd July 2007, 11:45 AM   #6
thank you.
but those new Cornell-Dubilier 381LX are really small for the capacitance they carry.
maybe in te old days, "computer grade" caps = high quality but not these days?
Old 3rd July 2007, 11:55 AM   #7
Computer grades have high ripple values, low leakage current values, generally have high voltage surge values.
Ultimately boils down to high reliability and a long life expectancy.
Some capacitor manufacturers did/do not use the term Computer Grade, but label their electrolytics as Long Life grade, the ones by Rifa and Siemens/Epcos for instance.
Most buy NOS big can CG's at really affordable rates, if you check the retail prices of the big bottles you'll find out they're pretty steep, $125 for a single big boy cap is not uncommon.
A couple of years ago i bought a large number of factory fresh 12-can CG boxes, turned out they couldn't handle the surge values of the big computer powersupplies they were ordered for.
The company had to dump a containerload of these caps because of the design mis-judgement.
Downside is that those CG's measure 9" in length, 3" diameter and weigh 2lbs each, good for constructing very sizeable amplifiers only.
Old 3rd July 2007, 12:08 PM   #8
Luke is online now Luke  New Zealand
Send a message via AIM to Luke
Is it ok to use these big Computer Grade Caps if they are like 10 years old?
Old 3rd July 2007, 01:04 PM   #9
the least you should do is reform them.
It would take a fair bit of kit and knowledge to test whether the ESR has deteriorated.
I believe reforming does not bring back ESR, only restores spec leakage.
regards Andrew T.
Old 3rd July 2007, 01:07 PM   #10
ssmith is offline ssmith  France
depends if they're used, and how they have been used. Once you figure this out you can refer to the datasheet for that particular cap and compare against the lifespan specs.
do a search also here to look for reforming caps that have been sitting on the shelf unused for a long time. This is a subject that has been addressed here before.
Rebuilding a DAC Audio grade or Computer grade caps? gto127 Digital Source 0 28th January 2009 09:17 PM
Computer Grade Capacitors Witchdoctor Tubes / Valves 14 6th January 2006 04:12 AM
Computer Grade/Inverter Grade Cap TunaFish Parts 2 11th March 2005 03:51 PM
Computer Grade Cap or Inverter Grade Cap??? TunaFish Tubes / Valves 10 11th March 2005 08:48 AM
Computer grade caps joke Pass Labs 19 19th September 2002 12:21 PM
Page generated in 0.11478 seconds (77.97% PHP - 22.03% MySQL) with 10 queries
