| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hi
I have a little problem with soundsystem: Yamaha RX-497 reciever and Dynacord DL92 speakers (4 speakers, 2 different sections). The amp is too much for the speakers and one of my coworkers doesn't seem to understand that. Almost every morning when I go to work I find that the amp's volume is almost at maximum. I'm afraid that the speakers won't hold on very long. Is there a possibility to create somekind of protection circuit for the speakers (e.g. limiter or clipper) that will disconnect the speakers, when the signal is too high for the speakers. Thanks for helping
#2 |
Murphy's Law : $10 transistor will always blow before the 10 cent fuse. Murphy was a optimus. __________________ Ret. USAF |
#3 |
to XEAGLEKEEPER: tnx for your reply, but this isn't what i'm looking for. The device you recommended will control the inputs gain depending on the signal level in output. Since the reciever has an built-in FM tuner, which is also used, and an external CD changer, then the effect will only be on the CD changers signal. And the damage can still be done, when using FM tuner.
But thanks again for your answer. |
#4 |
Disable the internal FM tuner and Run a seperate FM tuner with the suggested project.Or get some speakers that will take the abuse.........................................Dave
| Thread Tools | |
| Dynacord eminent 100 | pigsnoot | Solid State | 6 | 13th June 2009 10:55 PM |
| Dynacord MV46 as a compressor | fredriksweden | Tubes / Valves | 1 | 1st June 2009 12:26 PM |
| dynacord echocord s65 | jaguarecho | Parts | 0 | 1st March 2009 06:01 PM |
| Dynacord power mate 1000mk1 | amptech | Solid State | 0 | 30th January 2009 11:04 PM |
| Dynacord amps? | millwood | Solid State | 1 | 23rd September 2003 03:28 PM |
| Page generated in 0.12380695 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
