Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th June 2007, 03:08 PM   #1
jarthel is offline jarthel  Australia
Default bg and suggestions of leaving the amp on
this has been said countless times.
I am just wondering if the the statement is true for any use of a BG whether it's a decoupling cap or power supply cap and other applications that uses elcaps.
Thank you.
Old 28th June 2007, 04:29 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Well.... "wet" caps has a limited life time determend by age, Working Voltage and "On hours", so for that part you should turn your amp off......
However the Inrush current on the caps (when discharged) when turning your amp on again also "eat" some of the life time...
So the answer is
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 29th June 2007, 01:57 AM   #3
I believe people's reason for leaving the amp on is that BG loses their "break-in" if the amp is turned-off and needs to be broken-in again.
not sure if this is true hence the reason for this thread
Old 29th June 2007, 02:16 AM   #4
mpmarino's Avatar
Well, I think you can expect limited life expectancy regardless - who knows, maybe 20 years? That's far enuff in the future where I personally don't worry about it.
I think Nelson's X amps go into standby where the caps and psu stay on - when you press the front panel switch. I think he's keeping the front end warm and is not too worried about the caps dying too early<I could be wrong bout this..
Crazy Yankee.
Leaving D.I.Y everything must go sale...... exurbia Swap Meet 36 15th October 2008 04:42 AM
Leaving Class A Nelson Pass Pass Labs 31 29th August 2008 12:19 AM
Leaving X-former powered up Wynand Power Supplies 4 16th May 2006 02:07 AM
You all are better on without me / Let's talk about Dice45 leaving dice45 Everything Else 59 6th December 2002 05:15 PM
Leaving. fdegrove Everything Else 23 2nd December 2002 09:36 PM
Page generated in 0.07892 seconds (71.44% PHP - 28.56% MySQL) with 10 queries
