diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Where to buy PCB Drill bits in Hong Kong ? (http://www.diyaudio.com/forums/parts/10424-where-buy-pcb-drill-bits-hong-kong.html)
audio_cf 28th January 2003 06:35 AM
Where can I find not to expensive PCB Drill bits HSC carbide in Hong Kong ?
///CF
jmpsmash 29th January 2003 06:25 AM
Re: Where to buy PCB Drill bits in Hong Kong ?
///CF
Ap Liu street in Sham Shui Po (reachable by MTR) should have it.
fmak 29th January 2003 07:02 AM
Re: Re: Where to buy PCB Drill bits in Hong Kong ?
[QUOTE]Originally posted by jmpsmash
[B]
Just use ordinary drills from hardware stores; they are so cheap in HK. Unless you are proeducing en mass. Carbide ones are not cheap even in Ap Liu.
audio_cf 29th January 2003 07:34 AM
I have tried normal HSS drills and it doesnt work. Maybe I can get 2 - 3 decent holes before the holes start to look more like craters then holes and the copper is ripped apart from the laminate.
///CF
fmak 29th January 2003 10:48 AM
[QUOTE]Originally posted by audio_cf
[B]I have tried normal HSS drills and it doesnt work. Maybe I can get 2 - 3 decent holes before the holes start to look more like craters then holes and the copper is ripped apart from the laminate.
I don't have that problem with drills bought in Hong Kong. What are you drilling and have you the right speed?
Some HSS drills bought in UK are crap.
audio_cf 29th January 2003 10:54 AM
I have used a Bench drill press at the highest speed it
can 2800 rpm. Do I have to use a higher speed with the HSS drills ?
The HSC drills are so fragile so thats why I need some new ones in sweden they are redicolusly expensive. I have seen in china a long time ago HSC drills for about 1,5 EUR a piece!
///CF
SkinnyBoy 29th January 2003 10:56 AM
[QUOTE]Originally posted by fmak
[B]
lol, its funny cos you always delete the end of the quote script.. :) yeah, using a standard electric hand drill will dive poor results... :)
fmak 29th January 2003 12:53 PM
///CF
You need a proper drill 5000 to 10 000 rev/min
Copyright 1999-2017 diyAudio
