Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th June 2007, 01:41 AM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default Tech Tricks - - how to remove multiple pins?
Hey all you solder junkies/monkies
Lets say you have a dual rca jack, soldered to a pcb. There are 4 or 5 large pins, soldered through the board, maybe almost a 1/4" apart each. And the jack isn't very flexible.
Anyone have any good tricks for easily removing such a large, multiple-pinned piece?
I've been sucking the solder off, then individually heating pins and pulling them out a little at a time. But it is slow and messy.
GIVE ME A BETTER WAY!!
Old 27th June 2007, 01:56 AM   #2
Default Re: Tech Tricks - - how to remove multiple pins?
1) Cut the part into pieces which can be removed separately when the part is much less expensive to replace than the rest of the board.
2) Use a heat gun
3) Use multiple soldering irons
Old 27th June 2007, 01:57 AM   #3
OzMikeH is offline OzMikeH  Australia
Assuming the board is small enough to hold in your hand.
put excess solder on the joint.
Hold the board vertically, between 2 fingers and thumb. with the joint at the bottom,
melt the solder, holding your hand about 2 inches off the table, put a fair bit of heat in.
withdraw the iron, quickly bang your wrist against the table while the solder is still very hot. you should be holding the board so it doesn't hit the table and get damaged.
the shock from banging the table with the "flick" from the way your fingers flex shakes the solder off.
if there is some clearance around the pins this works very well, Much better than a solder sucker. I use this method for most things except wher ethe pins of the part fit very closely through the board sich as ICs.
Old 27th June 2007, 02:20 PM   #4
I_Forgot's Avatar
Use a propane torch.
I_F
Old 27th June 2007, 06:00 PM   #5
Minion is offline Minion  Canada
I have used a Propane Torch before to remove parts...I just heat the underside of the Board and when I see the Solder starting to melt I bang the board and the components Fall out, But you can easilly dammage some more delicate components this way.....
If I don"t need the PCB that the Parts are connected to I will usually Break the Board into Pieces with the components in Place and then remove the Parts One pin at a Time.....
I also believe there are Solder Tips that are shaped like the Components Pin configuration so it can heat all the Pins of a component at one time for easy quick removal.....
Cheers
Old 27th June 2007, 09:44 PM   #6
cuibono's Avatar
thanks everyone for the good ideas.
I want everything left intact afterwards, so I will have to proceed carefully. A propane torch sounds cool, but I think it might be a little too much...
Anyone have a link for the solder tips with unusual shapes?
Cheers
Old 27th June 2007, 10:08 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
The professional (expensive, mind) method is to use a desoldering station. It's an iron with a hollow tip connected to a vacuum cleaner (alright, a small pump in the base station) and energised by a finger switch in the iron handle. They're dead good if looked after carefully.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 27th June 2007, 10:31 PM   #8
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
If you've got money to throw around a desoldering station is simply wonderful for removing through hole parts. A cheap alternative is to get a desoldering iron from Radio Shack. Suction is accomplished using a little hand operated squeeze bulb. If you don't like the bulb right on top of the iron you can fit some silicone tubing (like the kind used with aquarium pumps) and relocate the bulb wherever you like. I often use my foot to operate it since my two hands are busy holding the board and the iron.
Brian
Old 28th June 2007, 05:31 AM   #9
If u want to use desoldering pumps/stations, use them with solder side down. The gravity helps to suck/remove the solder.
Gajanan Phadte
Old 28th June 2007, 05:24 PM   #10
Here is a Place that sells different Soldering Tips for removeing SMT and TO Parts....
http://www.okinternational.com/product_soldering/
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 05:24 AM
New tricks for an old dog greenie512 Full Range 2 12th January 2007 11:58 AM
Pot Installation Tricks?? Dominick22 Chip Amps 11 6th March 2006 01:26 PM
Page generated in 0.10504 seconds (80.83% PHP - 19.17% MySQL) with 10 queries
