| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Get a few rolls of solder wick, in different dim's...wet the joint with some fresh tin, and then wick away......
It is the most gentle way if you want to preserve the PCB. Even desoldering irons are pretty tough on the PCB,and can cause delamination of the copper tracks, and all the special tips are quite expensive.. Trust me.... I've tried them all. |
#12 |
For really awkward parts (especially relays) I cut a small piece of 1mm copper sheet stock just big enough to cover the pins, drill holes in the pin pattern (just only big enough for the pins to be visible), heat this up with paint stripper gun and tin liberally with solder then place it on the board, keeping the heat up with a 100w iron on the back. Part comes off toot sweet and time board is exposed to roasting is minimised. As soon is part is off, remove copper plate. For things like 40 pin DIL patterns etc, no holes necessary, it just has to fit snugly between the pins.
M |
#13 |
hey mobyd, that last idea was pretty sharp.
I've been using a desoldering iron (Radioshack), its simple and it works, it just always leaves a little solder, and then the pin sticks to the board. So I have to do round-robin, moving each pin out a little at a time.... |
#14 |
yep... stiky pins suck... I tend to keep a thumnail available to wriggle th eoffending pin, while the solder sets... so it stays loose.... Luckily I don't use soldermasks, so it tends to be easy to just apply some flux and flow the solder away with gravity, and maybe a few ticks against the desk.
| Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 | tyler477 | Solid State | 1 | 31st October 2008 05:24 AM |
| New tricks for an old dog | greenie512 | Full Range | 2 | 12th January 2007 11:58 AM |
| Pot Installation Tricks?? | Dominick22 | Chip Amps | 11 | 6th March 2006 01:26 PM |
| Page generated in 0.07524 seconds (73.56% PHP - 26.44% MySQL) with 10 queries |
