| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
When you mount a transistor to a heatsink and use an isolater, like a Silpad. How can you be sure its isolating correctly. my amplifier is drawing too much current on the positive rail, and I have this suspicion that is the problem. However I can't figure out how to trace it out. Thanks.
#2 |
The bare metal surface that dissipates the heat is in the same potential as collector so simply measure resistance from collector to ground.
#3 |
What part of the transistor is the collector, would that be the Gate? If you could give it to me in terms of Gate, Source, and Drain, that would help.
#4 |
Ok, I didn't realize you were talking about field effect transistors..
Gate corresponds to bipolar transistor's base Drain corresponds to collector Source corresponds to emitter |
#5 |
as far as I know the middle pin of SIL transistors is connected to the mounting flange. This applies to BJTs, Vertical FETs and Lateral FETs. Regulators are different. Look up your data sheet, the information is detailed there.
regards Andrew T. |
#6 |
Thanks Andrew, I looked up the datasheet and didn't see where it said that. None the less, you are right, and I figured it out eventually. I found the problem, some left over heat sink compound that was mis-placed. It's currently playing music, so all is well. Again, thanks to everyone though.
#7 | ||
that was not your problem. What else did you correct/change/do when you cleaned off the excess compound? Quote:
The legs/pins will be coded. A note will detail which code belongs to which pin type (G D S).
regards Andrew T. |
| Thread Tools | |
| Isolated Ground | ak_47_boy | Parts | 4 | 24th June 2007 02:51 AM |
| Audio coupling signal with ground isolated | Elias Novaes | Solid State | 6 | 27th April 2007 02:31 AM |
| What is the difference between an isolated IC and a non-isolated IC? | DJ Exprice | Chip Amps | 16 | 20th June 2006 07:34 AM |
| Isolated ground GFCI | pooge | Parts | 0 | 12th October 2004 09:58 PM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 01:55 PM |
| Page generated in 0.24772811 seconds (46.03% PHP - 53.97% MySQL) with 10 queries |
