What do you guys reccomend for binding posts?
I am rebuilding a pair of MK3 dynaco monoblocks. I need binding posts. I have been going around and around on what to use.
I will be using banana plugs. I just need a good clean solid reliable connection. I don't want to have to take the amps back apart to replace connectors with bad plating or whatever.
Whats the best bang for the buck? I can't afford WBT.
Ideally I could get 6 so I could have posts for common, 4 and 8 ohm taps on the back.
Thanks everyone - Evan
I was considering both the apexjr units AND the parts express ones.
Glad you guys have actually seen them up close and personal. I was worried the build quality wouldnt be so great.
The audionotes look promising too though.
Thanks folks, keep the info coming!!!
Evan
Evan
Do you want a better picture ?
