| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does any one have the experience if a Tek 2225 is capable enough to perform all the neccessary measurements in amps both Tube and Solid ?
Iis capable of measuring the lowest audio frequencies 5 - 20 Hz with accuracy ? |
#2 |
TEK2225 is a analog 50Mhz dual trace with magnifier scope.
a common oscilloscope with tektronix quality. For slow signal I suggest the new Digital TDS1001B (with USB) It is also recommended for signals hardly triggerable but consider that the screen of the TDS1000 and 2000 Series have a 1/4 VGA screen = 320x240 pixel (less than an old EGA !!!) I think that the normal signals are seen better surely on the analogical scope. bye |
#3 |
Hi aroS3,
Yes. I've worked with less - and better. This scope will serve you well. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#4 |
hi
I have 2235, its 100M and is very good scope, I use it for up to 250k, but has no problems going into Mhz area |
#5 |
Those are real nice scopes.Should serve you well for just about anything audio in nature.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
| Tektronics 2225: No power | theAnonymous1 | Equipment & Tools | 0 | 15th September 2008 01:07 PM |
| Jbl 2225 H | bluesman | Swap Meet | 0 | 23rd April 2006 10:40 PM |
| Tektronix 2225 | jasont | Parts | 8 | 14th October 2004 11:28 AM |
| Tweaking Marantz 2225 | faxurda | Solid State | 1 | 23rd October 2003 07:50 AM |
| Page generated in 0.07532 seconds (72.65% PHP - 27.35% MySQL) with 10 queries |
