Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th June 2007, 04:52 AM   #1
ShaunL is offline ShaunL  Australia
Default Low Pass Filter in line with a Piezo Transducer
I'm new to this forum. Just wondering if anyone could help me out with something.
I've built a stomp box which is basically a box with a pickup inside. They're used by tapping your foot on them to get a percussive accompaniment while playing other instruments.
The problem is, that they require quite a bit of EQ to roll off the high and mid frequecies.
I want to place a Low Pass Filter between the Piezo transducer and the output of the box but am unsure about how to go about it and what value capacitor/inductor etc to use. I'm pretty sure the Piezo has an impedance of 600 ohms... and i would like the LPF to roll off frequencies above about 400hz.
If anyone can help me out, that would be great!
Thanks.
Shaun
line level high pass filter rbrockman Analog Line Level 3 13th December 2008 05:21 AM
Piezo Transducer Trigger 4A Analog Simmons Drum Module modorange Instruments and Amps 8 21st December 2007 04:23 AM
Piezo sounder as a transducer Pbassred Parts 8 9th September 2006 08:19 PM
Line-Level Low-Pass Filter Design JustinAtGT Chip Amps 10 31st May 2006 08:48 AM
Page generated in 0.06167 seconds (66.37% PHP - 33.63% MySQL) with 10 queries
