Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th June 2007, 08:53 AM   #1
Default Trying to repari a GPS
I have a GPS. The antenna broke when it fall down. i opened it, and saw the antenna broke, but damaged the internal conectors the are used for conecting the lcd. This lcd has a flat plastic conector, that carry the rails for the lcd. Anyone know if this conector are standard? and if so, where can I get them?
Old 14th June 2007, 02:52 PM   #2
MaxS is offline MaxS  France
Maybe a picture will help members to answer you !
Ca marche pas ! Tu ne l' as pas branché non plus ....
Old 14th June 2007, 03:07 PM   #3
FastEddy's Avatar
For small solid state GPS units == ... just put the antenna back in place as best you can and give it a small hit of solder. (You may not even need the solder as very close proximity of the antenna and lead will be good enough.)
As for the internal connector, repairing the connections is best as replacing the hard to find connector may be more work and less reliability than its worth.
Old 15th June 2007, 07:35 AM   #4
On the backside of the antena, has a zone that seems like ceramic,what is broken, I guess maybe that is the problem? So´, I´m not sure if really can be repaired itself..
Regarding to the conectors, how doing the repairing? The problem, is that I broke a little leg there, and the other problem is that is missing the flap that pressed the lcd conector. what do you suggest?
I´ll try to get a photo from there.
Old 15th June 2007, 01:06 PM   #5
antenna foto
Old 15th June 2007, 01:07 PM   #6
the lcd flat conector, has 49 rails, it´s length is 25.5 mm aprox.
Old 15th June 2007, 01:12 PM   #7
this is the conector on the mainboard, it has 50 pin for the lcd conector, what uses 49 of them. As you can see, is missing the last 3 pin on the right side, so I´m not sure how could repair that. Also is missing the flap that would press the lcd conector.
Can´t be get another new conector like this? 25 mm, for 50 pin, is not a standard?
Old 15th June 2007, 06:07 PM   #8
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
If you want to repair that you will need to replace the connector. I'm sure you could find a replacement one at Digikey, Mouser, or other parts supplier. We use similar ones at work and I can't remember who makes them but they are a pain to replace...
If you are very good with a soldering iron you can remove that connector without lifting any pads. However, the recommended tool for removing connectors like that one is a hot air pencil.
Brian
Old 16th June 2007, 04:46 AM   #9
FastEddy's Avatar
Re: " ... antenna foto ..."
I would not try to fix it at all ... except any metal foil on the back side. Otherwise the broken piece should be left "in state" and don't bother trying to repair it ... it will work to 90% of usefulness as is.
Old 17th June 2007, 06:26 PM   #10
Umm, hot air pencil are expensive, not? maybe could pay for the soldering service on a SAT. Where your are located? Maybe any of you could do the work?
How must I search for the conector? Type, name? how are they called?
I´m guessing if this type of antennas are standard for many GPS units, or is excluive for this firm. It´s a Garmin Nuvi, and I suspect they will put me some problems on selling me only the antenna, or I suspect they will charge a huge amount of $$.
Page generated in 0.11515 seconds (82.06% PHP - 17.94% MySQL) with 10 queries
