| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a Belkin PF60 which has tons of filtering inside it. The layout is pretty easy to follow, and I can identify the obvious parts like relays, chokes, and AC rated caps, but there are a few that I am not quite sure of. I have three high-res pictures here:
http://jamiedamanpour.com/pub/Belkin_PF60/ 1. In IMG_0225.jpg, you can see a black cylinder encased in plastic near each outlet. They are surrounded by MOVs and are just below the ferrite cores. Any ideas? You can get a closer look in IMG_0226.jpg. 2. Also in that picture, you get a good look at some 1/4W resistor sized silver things with green marking on one end labeled SW-110T, so they may be directional like a diode. By the ratings, they have to be series devices. 3. In IMG_0242.jpg you see a small silver cylinder with blue lettering on a white label hiding in the shadow of the orange MOVs. Is that a gas discharge tube? 4. There are two enamel coated coils wrapped on vertical black cylinders in the lower left corner of IMG_0225.jpg near the MOVs and whatever mystery part #2 is. If anyone knows what these are, I would appreciate some help. |
#2 |
part 4 are iron cored (ferrite) inductors. Those green ended things seem familiar but I can't recall where! Is the Rxx label next to part 1 significant?
regards Andrew T. |
#4 | ||||
Warp Engineer
On Holiday
- Dan |
#5 |
1: AC Current Sensing Transformer
![]() 2: One-Shot Thermal MICROTEMP® Fuse 3: Gas Discharge Tube (GDT) 4:Vertcial Mount Power Choke Ferrite Rod Core Regards James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
#6 |
are the thermal fuses there to cut off power if the MOVs catch fire/overheat?
regards Andrew T. |
#7 |
I think the MOVs and thermal fuses are built as little ladders where the hope is to have an MOV divert current long enough for a fuse to open. If too much of a surge gets through, there is another step of MOV and fuses.
#8 | |
AndrewT wrote
An open MOV will go un-noticed jeoparding the equipment. There are newer self indicating type MOVs with integral thermal fuse. Gajanan Phadte |
| Identifying SMD parts from car monitor | Speeed3 | Car Audio | 4 | 12th November 2008 04:40 AM |
| UCD as power conditioner | Daveis | Class D | 3 | 28th October 2006 08:39 AM |
| Identifying parts in this power supply | newbie06 | Digital Source | 29 | 28th October 2006 02:58 AM |
| DIY power conditioner? | leadbelly | Power Supplies | 8 | 14th March 2006 03:09 PM |
| power conditioner | diram6 | Parts | 0 | 2nd December 2005 03:06 AM |
| Page generated in 0.11363 seconds (77.37% PHP - 22.63% MySQL) with 10 queries |
