Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th June 2007, 03:10 AM   #1
Default dual gang audio pots and where to find them
I had no idea these parts were so hard to find. When I built my amp, I used a single gang pot for each channel's volume control. It got to be kind of a pain tweaking the dual volume controls until both channels were equally loud. Radio Shack has a 100k dual pot but that's too high a resistance for my application. Where is a good place to get a 10k dual gang pot?
Old 8th June 2007, 05:01 AM   #2
djk is offline djk
djk's Avatar
How much do you want to spend?
OEM quality:
http://www.futurlec.com/Potentiomete...10KADUAL.shtml
Candidates for the Darwin Award should not read this author.
Old 8th June 2007, 02:35 PM   #3
Apex Jr is offline Apex Jr  United States
I have some Mil-Spec RV4 types in stock....
1/4" single shaft not concentric ...
Steve @ Apex Jr.
steve.apexjr@prodigy.net
Old 8th June 2007, 04:09 PM   #4
radtech is offline radtech  United States
You could try mouser.com part# 313-2420F-10K, it's a 24mm Alpha brand. I bought a couple of this style a little while back, seem to be pretty good construction.
Old 9th June 2007, 12:24 AM   #5
Default Thanks for the quick response!
THank you all. That was very helpful. Since I already have a hole drilled in the chassis front panel, I thought I'd put a balance control in the hole. Anyone know how to wire one of these and can I use one of my original pots to do it?
Accuracy of Dual Gang Pots dano12 Solid State 23 20th April 2009 11:46 PM
WTB dual gang 16 mm 100K PC mount pots chipco3434 Swap Meet 0 9th December 2006 01:44 AM
F.S. Noble dual 10K audio pots - new @ $6.50 each Mr Dijon Swap Meet 2 9th November 2006 01:33 AM
Need info on Good dual-gang log and antilog pots groovietuner Parts 1 29th April 2005 03:54 AM
WTB sealed cermet 50K dual gang audio Prune Swap Meet 2 28th May 2004 08:19 PM
Page generated in 0.09786 seconds (74.74% PHP - 25.26% MySQL) with 10 queries
