Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th June 2007, 02:48 PM   #1
Default Replacement for humble RCA
I have been using Hirose 3 pin connectors as a replacement for the ancient RCA in all of my new projects.They are cheap; $1.92 for the 3 pin receptacle; and $3.57 for the 3 pin plug.The Male pins are brass and silver plated;the female pins are phosphor bronze and also silver plated.The bodies are made of Polyamide and Polyacetal resin.They are blue in colour and I purchase them from Digikey.
Old 6th June 2007, 02:51 PM   #2
Did it Himself
richie00boy's Avatar
They look like 3 pin DIN plugs
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th June 2007, 04:42 PM   #3
Why not use these guys?
http://en.wikipedia.org/wiki/XLR_connector
They're not that much more expensive than the Hiroses, and you can get XLR connectors & cables just about anywhere.
Old 6th June 2007, 05:35 PM   #4
I_Forgot's Avatar
What's wrong with BNCs?
I_F
Old 6th June 2007, 05:48 PM   #5
Here is another Pic.Yes they are similar to Din plugs.The receptacles are about 12MM in diameter.They are also available with seven pins.
I consider them a poor man's Lemo or Redel connector suitable for home built equipment.
Old 7th June 2007, 10:44 AM   #6
ssmith is offline ssmith  France
I_F
they limit you to using only coaxial cable??
Old 7th June 2007, 10:52 AM   #7
Did it Himself
And are a bit of a pain to put together.
Humble Statement wigginjs Multi-Way 12 19th December 2007 04:11 PM
Ther humble LED jmateus Everything Else 2 10th December 2007 02:34 PM
Humble Hifi uli Multi-Way 2 25th June 2004 02:51 PM
My humble A30 Dennis Hui Pass Labs 16 18th November 2003 09:36 AM
Page generated in 0.09375 seconds (72.49% PHP - 27.51% MySQL) with 11 queries
