| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm building a simple passive pre-amp, and looking at the "best possible" attenuater solution.
On my way I found this on the WEB. The special "Bob Crump tweak" is (for a 25K stepped attenuator) to add 2 x 250K Vishay S-102 reses for each channel ... from input to output and from output to ground. It then takes 40-45 days solid use to break in completely!! Does this idea work with a passive pre-amp? What impedance should the attenuator itself have when used with this solution in a passive pre-amp. And the are the values for the S102 the same in this case. Please help Vogue Denmark |
| Robert Crumb audio interview | 7n7is | The Lounge | 6 | 29th August 2008 05:04 AM |
| Volume Pot vs Stepped Attenuater | Zap | Tubes / Valves | 49 | 27th May 2008 03:52 AM |
| let's tweak this amp!!!!! | Flavio88 | Solid State | 34 | 14th August 2006 06:50 AM |
| Can the 5V in the T-amp be tweak? | ChuckT | Class D | 0 | 13th October 2005 09:25 AM |
| new tweak? | mirlo | Everything Else | 1 | 21st May 2004 11:02 PM |
| Page generated in 0.04920 seconds (77.62% PHP - 22.38% MySQL) with 10 queries |
