Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
NE5530N op amp or substitute?
Old 6th June 2007, 03:02 AM   #11
FastEddy is offline FastEddy  United States
FastEddy's Avatar
" Match , Like No Data NE5532(4) NE5533(1) NE5534(5) NE5535(1) NE5537(1) NE5539(2) ..." From http://www.alldatasheet.com/view.jsp?Searchword=NE5530D ...
http://www.fairchildsemi.com/ds/NE%2FNE5532.pdf ... is a pin for pin substitution for the '5530.
http://focus.ti.com/docs/prod/folders/print/ne5532.html ( http://focus.ti.com/lit/ds/symlink/ne5532.pdf ) ... is a pin for pin substitution, and some free samples are available.
http://www.analog.com/en/prod/0,,AD8066,00.html ( http://www.analog.com/UploadedFiles/...D8065_8066.pdf ) ... is a pin for pin replacement w/ better specs IMOP.
http://focus.ti.com/docs/prod/folder...t/opa2134.html ( http://focus.ti.com/lit/ds/symlink/opa2134.pdf ) ... is a pin for pin replacement w/ better specs IMOP. ... I'm currently using these in my "kitchen table" summing amp / sub woofer driver (see my icon to the left) ...
Old 6th June 2007, 03:17 AM   #12
Conrad Hoffman is offline Conrad Hoffman  United States
So has anybody been able to find a datasheet for the 5530? There seem to be lots of them available, just not in small quantities or low minimum orders. The only summary I could find said it's a 3MHz dual with 150nA input current. In any normal app I wouldn't hesitate to sub it with any of the parts listed in the above post, but as part of a power amp, I'd be more cautious. A part with "better" specs might not be stable. Or it might work better than it ever worked before. You'd want to check for oscillations and such.
Old 6th June 2007, 03:23 AM   #13
FastEddy's Avatar
" ... has anybody been able to find a datasheet for the 5530 ..."
" " Match , Like No Data, NE5532(4) NE5533(1) NE5534(5) NE5535(1) NE5537(1) NE5539(2) ..." From http://www.alldatasheet.com/view.jsp?Searchword=NE5530D ... that's what you get from a googler search for '5530 = no match / no data = ... although there may be something out there, I don't usually read the second page search results ... bad habit, but ...
Old 6th June 2007, 09:50 AM   #14
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Originally posted by javey
I was replying to gold and others. QSC said 5530 was obsolete(and they are unless you order from the $300 minimum warehouses) and told me 5532's would not work. They did not make any suggestions as to what would,simply saying save yourself the hassle and buy a PLX.
I just can't see how they can say 5532 won't work. It's unity gain stable and has good power capabilities. You have confirmed the 5530 is a dual device, so all that's left really is the pinout. Maybe they were being lazy/arrogant and just want a new sale.
The only other possibility is that 5530 is a transconductance amplifier. Unlikely though. I say drop a 5532 in and see what happens.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th June 2007, 02:56 PM   #15
javey is offline javey  United States
This is the unedited response cut and pasted from QSC's Thanh Nguyen who I also asked about what were the stock OT's and drivers.
"If itís not in good condition, I suggest buying a new RMX850 instead of restoring this amplifier. QSC Technical Services no longer service the A-Series amplifiers since they were discontinued in the early 1980s.
Note that ECG130/219 were not QSC parts; Op-amp NE5532 would not work properly in A32 circuitry and NE5530 is obsolete."
Thanks Eddie for all the info! I'll let you guys know as soon as I get my hands on these and throw them in.
Old 6th June 2007, 03:38 PM   #16
FastEddy's Avatar
Javey: ... enough info to do it? ... How about this:
I own three QSC model 1400's, one of which I have gutted for the chassis and transformer and some hardware. All were working when they were removed from service as part of dance hall / house PA.
I intended to dispose of the other two 1400's, either to someone willing to pay shipping costs or into the dumpster ( ).
Do you want one? ... ~39 pounds each / ~ US$32.00 for UPS to Michigan ... email me.
Old 6th June 2007, 06:27 PM   #17
Gold_xyz is offline Gold_xyz  Italy
Gold_xyz's Avatar
I agree at 100%
Surely the NE5530 can be replaced with the common amp-ops
There is perhaps need to replace some component.
When QSC AUDIO has abandoned the NE5530 It has modified the Schematics.
(To See QSC USA370
http://www.qscaudio.com/support/libr...ies/usa370.pdf
and QSC USA400
http://www.qscaudio.com/support/libr...ies/USA400.pdf
The following schematics (with NE5532) change :
Balancing Resistor R19-R20(A32) 22Ohms NF 1W
and increase R17-R18(A32) to 6.8 Ohms NF 1W
Also loop feedback of 2nd Amp-op is enough critical and
with the new high performances amp-op it can be oscillate.
My English originates from here
Old 6th June 2007, 06:45 PM   #18
Gold_xyz's Avatar
After resistors substitution I suggest to install a socket (if not present)
for amp-op and try also these :
http://www.national.com/ds.cgi/LF/LF353.pdf
http://www.national.com/ds.cgi/TL/TL082.pdf
Old 6th June 2007, 06:52 PM   #19
Gold_xyz's Avatar
High power amplifier with class AB quality but with a compact and
light switching power supply PC-style..
I need to modify a PC-supply for +/-50 Vcc
Old 6th June 2007, 07:24 PM   #20
FastEddy's Avatar
" ... High power amplifier with class AB quality but with a compact and light switching power supply PC-style ..."
Oh contrare' ... These old QSC 1400 have a plain vanilla "brute force" type 1400 VA power supply with a very heavy transformer (~25 pounds) and regular full wave rectifiers & large electrolytic caps = +/- 76 VDC per output power rail and +/- 15 VDC for the first stage, protection & mute circuits === definately NOT a switching supply ( http://www.qsc.com/support/library/s...20One/1400.pdf ) ...
OF special interest here: The QSC 1400 uses the afore mentioned NE5532 and the first amplification stage ... ... and that's basically why I have junked one of the amps, saving the chassis & PS for a "better" amp board ( aussieamplifiers.com ... the NX500NL times two).
Also your english is quite passable ... no need to appologize for it at all. (Mine is not that great ... )
NE5530N op amp or substitute?Hide this!Advertise here!
AN630 Substitute s2kov Parts 9 27th November 2007 10:11 AM
LF357 J fet op amp substitute? Burnedfingers Solid State 1 20th October 2007 02:27 PM
2SD873 substitute ? garnet Parts 1 27th September 2007 09:32 AM
tr substitute dexter Solid State 5 29th April 2001 02:53 PM
