Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th June 2007, 06:15 AM   #1
jnb is offline jnb  Australia
Default What is this
It is from the mains side of a smps.
Old 4th June 2007, 06:16 AM   #2
Frank Berry's Avatar
It looks like a fuse. The ultimate flameproof fuse.
Frank
Old 4th June 2007, 06:18 AM   #3
impsick is offline impsick  United States
impsick's Avatar
it does look like a fuse but i had some glass resisters that looked like fuses similar to that.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 4th June 2007, 06:35 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
It could possibly be a neon lamp. Is there any gap between the "resistor" and the wire in the bulb?
/Per-Anders (my first name) or P-A as my friends call me
Old 4th June 2007, 12:57 PM   #5
No, under the heatshrink it is connected as for the other side. It measures an open and is marked as follows:
D668
DSA
302H
Old 4th June 2007, 01:33 PM   #6
It may be a resistor which can handle lots of power without burning out. Like a bulb or lamp which is under a vacuum. When the output power increases going through it, its resistance goes up, but can handle lots of power, because the air will not get to it and burn it up as quickly as if it was exposed to the air. Like a safeguard for a output stage to allow compression when the output stage reaches critical output level.
Old 4th June 2007, 02:04 PM   #7
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
How about thermal stability.
Looks like Sponge Bob has killed another thread.
Old 5th June 2007, 07:46 AM   #8
Oh, like a filament that acts like a quasi CCS you mean, like Pass' en-lightenment? Interesting. I wonder if it would be of any use in an amp?
Old 5th June 2007, 09:28 AM   #9
I haven't read someone mentioning the sleeve.
Odd sleeve for a resistor lead, no ?
Old 5th June 2007, 10:49 AM   #10
impsick's Avatar
not really. i always see heat shrink on the leads of resisters and diodes, in older gear.
Page generated in 0.09341 seconds (76.72% PHP - 23.28% MySQL) with 10 queries
