Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st May 2007, 09:20 PM   #1
rnzr is offline rnzr  Estonia
Default Capacitor help please!
I replaced my Phonobox SE electrolyic caps with BlackGates and sadly i did touch one other cap on the board with my soldering iron...
It says "68nK 100" on it. And i gues it's MKP/MKT type...
Wondered what is nK? same as nanofarads - nF?
There are 2 of them on board. I need something to replace them so suggestions are welcome (for better ones too), their body length is 7,5mm.
Thanks, Ronald
Old 31st May 2007, 09:54 PM   #2
sandyK is offline sandyK  Australia
Judging by the photo, there doesn't seem to be anything special about them, such as close tolerance,polypropylene, etc.
I would just replace them with the "cheap as chips" 68nF 100V 5mm pitch poly caps from your local electronics store.
SandyK
Old 31st May 2007, 10:06 PM   #3
aerius is offline aerius  Canada
68nF, 10% tolerance, 100V. They look like generic caps as far as I can tell, if you have the full schematic of the phonostage you can figure out what those caps are for and how much of a difference an upgrade is likely to make.
Old 31st May 2007, 10:19 PM   #4
K is tolerence 10%
J is 5%
Although it may look a bit horrible it is actually very unlikey that you have done any damage to it.
As already stated it isn't anything special.
Old 31st May 2007, 10:25 PM   #5
Thanks for reply's!
I guess i use Wima MKS-2 caps then, they are quality ones.
Don't have the schematic and cant find it too.
I guess if i use 63V ones instead of 100V like they was originally it's more than enough cause the Phonobox SE input voltage is ~16VAC.
Ronald
Best PS capacitor RFENG Parts 3 19th January 2008 02:44 PM
what capacitor is this? abiedoodles Parts 10 12th December 2007 07:11 PM
Capacitor Help MorePower7701 Solid State 8 25th July 2007 06:41 PM
Capacitor esl dhole Pass Labs 1 23rd April 2005 02:18 PM
Capacitor or not? future Parts 2 24th June 2003 11:10 PM
Page generated in 0.09077 seconds (72.47% PHP - 27.53% MySQL) with 11 queries
