Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd May 2007, 08:40 PM   #1
Malefoda's Avatar
Send a message via MSN to Malefoda
Default MKP rated X2
Hi there,
on a source I want to change the older than old DC blocking caps, 0.33µF electrolytics, for better ones. Not the best, the aim is to improve the sound for nothing if possible. In are now 1µF MKS, but I find it's not to be left in. I've in hand 0.22µF MKP but X2 rated, MKT 2.2µF. Or even 0.03µF Siemens MKP. Does the X2 rated MKP fit? MKP is MKP, isn't it?
Thanks!
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 24th May 2007, 04:47 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
What is the value of the resistor it is connected to...?
Old 24th May 2007, 05:32 PM   #3
Did it Himself
richie00boy's Avatar
X2 rating is simply a safety failure mode rating.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th May 2007, 07:16 PM   #4
Malefoda's Avatar
So X2 is not a sound problem, MKP rules
Here is the pic of the output of my tuner, the closest resistors feeding the caps (my MKS here) are 2.2k. I don't know if they are the one you talked about Nordic, maybe to check the value of the caps?
Thanks guys!
Old 25th May 2007, 03:29 PM   #5
those two pots may be presets to control the level of signal fed to the amplifier.
If you can read off or measure their resistance then that may help.
The reason for asking is that a few components in the input are there to filter the signal before passing it to the amplifier.
There are usually a low pass filter and a high pass filter. The series capacitor and the following resistor to ground form the high pass filter that blocks DC from entering the amp and also attenuates very low frequency signals. The bandwidth of the following amplifier should/could affect choice of capacitor value.
The filtered signal should match the designer's specification and changing caps could change the way the amplifier behaves.
regards Andrew T.
Old 25th May 2007, 03:56 PM   #6
Malefoda's Avatar
Ok I see, but... can I use something I've got here ?
Old 25th May 2007, 04:29 PM   #7
Malefoda's Avatar
I'll try to draw the output of my tuner to help.
Old 25th May 2007, 05:10 PM   #8
Nordic's Avatar
you can try the .22uf, but it will likely sacrifice some low frequency extention. As said above, stick to original values, play round with types if you want to... those red caps (WIMA?) are normally fine...
Old 25th May 2007, 05:12 PM   #9
Malefoda's Avatar
OK thanks!
Old 29th May 2007, 02:34 PM   #10
Malefoda's Avatar
Got Wima MP3 0.33uF, do this sounds good or at least like the MKS? At least they are the right capacity.
Like these:
Over 500V rated electrolytics? Zap Tubes / Valves 2 17th February 2009 12:10 AM
if an NTC thermistor is rated... jarthel Parts 2 21st May 2007 12:06 AM
FREE Y2 rated CAPS HIPCHECK Swap Meet 0 21st October 2006 11:15 AM
75% of rated max. current too high? bequerel Tubes / Valves 4 13th June 2005 12:22 PM
Why would an amp put out 1/4 of its rated power? >> beady Car Audio 3 9th August 2004 05:10 PM
Page generated in 0.10585 seconds (85.07% PHP - 14.93% MySQL) with 10 queries
