Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th July 2007, 05:52 PM   #81
greenvalve's Avatar
Thank you for sharing this tweak Bud!
Would you list the order of greatest improvement vs placement please? Where exactly should these be placed for the most effect?
Such as (1) tube socket (2) speaker ground lug etc.
Also, have you used this with a turntable cartridge? I was wondering if the further down the chain the greater the improvement as is the case with many tweaks.
Thanks again!
Old 28th July 2007, 07:32 PM   #82
BudP is offline BudP  United States
BudP's Avatar
greenvalve.
I have pools in every piece of equipment I have running. There is no "scale of benefit added" here. You are only preserving information that would otherwise be stripped from the signal and turned into noise. So, you will end up doing it to every stage of your signal chain.
1. Phono cartridges require a very small amount of dielectric, three pieces of heat shrink (HS) tubing, other than PVC, each about 0.3" long per channel. I mounted them at the interconnect to arm wire junction on the cartridge return side, not chassis ground. Affects dynamic color, opens up bass information. One pool per channel only and even this much may swamp your cartridge, after hinting how good it could be. Just remove dielectric in 0.1" amounts.
2 Tape Deck. Ditto the preamp comments to follow, with the addition of one wire per playback head return, at the PCB connection, with likely even less dielectric than used on the phono cartridge. Affects dynamic color and low level signal coherence.
For the rest, the HS tubing should be 0.6" per piece unless you have Lowther DX 4 drivers. Then those pieces should be 0.8" per piece.
3. Cd / Sacd On the ground legs of the RCA jacks as they poke through the PCB and into whatever miserable ground plane the designers were allowed to use. Returns high frequency hash to it's original information content in both. Improves dynamic color in CD. Will need as many as four pieces of the pools applied to the common L&R channel ground buss.
4. Preamp's of all kinds, DAC's included. Applied to input and out put ground buss, usually at the RCA jacks, Also can be applied to the cathode of your driver tube, on the ground side of the resistor and away from tube socket and all other HV wiring. Can and will pick up EMF from the heater wires so careful routing is needed. Affects dynamic color and low level wide band signal coherence.
5. Power amp. Ditto the preamp.
6. Speakers, you can use differing amounts for each driver with a scale of around 3 wires per bass driver, 2 for mids and 1 for tweeters. Or, you can just use one at the input ground terminal. Affects all low level information content, sometimes alarmingly.
After you have experimented with all of this I suggest you learn how to EnABL a set of drivers, so you can hear all of the benefit available. The Electron Pools are beneficial, until you get too much dielectric material, but without the basically infinite resolution provided by EnABL'd drivers, you will only get part of the story.
Don't bother with applying these things to the signal side of the electronics. Our beloved professional EE's have done a superlative job here, as you will begin to find out, as you journey through pools, to EnABL'd drivers to cables that preserve tiny information content, as content, rather than noise or phase shifted colorations, and finally to transformers that remove all trace of zero crossing distortion and phase anomalous behavior. PM me about the output transformers and cables to suit, if they interest you.
Hurry along a bit everyone, I retire in 5 years and embark upon my new life, out of a shopping cart.
Bud
Old 31st July 2007, 02:00 AM   #83
Budp,
Do you sell the "add-on groundplane" wire that you are using? I would be interested in getting a couple of feet of the 140 strand material to do some testing on my setup.
Thanks for your time,
Donovan
Old 31st July 2007, 02:28 AM   #84
BudP's Avatar
Donovan,
Please PM me.
Bud
Old 31st July 2007, 09:24 AM   #85
Bob,
The board won't let me see your address. Can you E-mail me and I can reply?
Thanks,
Donovan
Old 6th August 2007, 04:52 AM   #86
soongsc is offline soongsc  Taiwan
soongsc's Avatar
It's amazing how people go through such extends in try and improve sound. I must admit the ground plane is the most mysterious part of electronics. Most analysis method treat it as fixed voltage level. I think if there is a way to do analysis and treat the ground plane as floating, there are many things we can observe.
Hear the real thing!
Old 6th August 2007, 06:03 AM   #87
Nanook is offline Nanook  Canada
Nanook's Avatar
Default groundside electrons and the EnABL process
I have been reading this thread for a little while, and have seen some of Bud's devices at the Vancouver Island DIYfest recently. I hadn't really thought much about them, but I have a little inside information from someone I trust that the effect sare real (nobody at the 'fest, but an aquaintance). So wanted or not, here are my thoughts.
first, regarding the "electron pool" or whatever term one might wish to call it: I've been thinking regarding the back EMF produced by the voice coil in the speaker drivers. As most know (even if they haven't done any physics or math or whatever), move a coil through a magnetic field (B field), a voltage is induced, and therefore an electromotive force that impedes the flow of electrons (current, and voltage) is created. I suspect that by creating an "electron pool", there exists an oportunity to reduce the back EMF.
regarding the EnABL process and the effects heard:
Obviously the boundaries are very important, otherwise why would all the time and energy be wasted on reducing diffraction at loudspeaker enclosure boundaries? Again, I am only putting this out there for a reasonable discussion and no mud slinging (hopefully Chris and others can attest to my sense of reason and a reasonable approach to many things audio).
Consider the $1.20 "trick" Sam Tellig stated in Stereophile several years ago. Take two quarters and place them on the front corners of a loudspeaker (just rest them there, no need for adhesive). Now put a dime inbetween the two quarters (even American coins will work!). Repeat for the other side. Listen. Remove the coins. Listen some more.Replace the coins. Listen. Come to your own conclusions.
Now ask a friend (audio buddy type) and do the same thing, but don't tell him what you're doing (ask him to close his eyes, or have the coins in place before he enters the room). Put on some tunes and listen.
Thinking back to quantum mechanics and boundary conditions and solutions of a wave function, it is obvious what the EnABL process is doing. Basically you are "perturbing" the wave as it hits a boundary and either scattering the diffracted waves in a uniform matter or dampening them out at the boundary. Either way it seems to me that the "time smear" reduction is really the control of unwanted diffraction. Period.
Maybe I'm wrong, but to me this seems like common sense.
Else how would Shun Mook and Mpingo and other well documented tuning devices "work" ? Just a thought.
stew -"A sane man in an insane world appears insane."
Old 6th August 2007, 07:01 AM   #88
BudP's Avatar
Nanook,
Your surmise on electron pools stands up for speakers but only, I think, for the E Field portion of wave propagation. However, take the same approach and move back through the amplification chain. The very same "sort" of effects are found in all of the pieces in the puzzle.
I am looking for a way to explore what is going on quite frankly. Not just because of "improvements" in sound quality, but because I am using some pretty similar concepts in my audio transformer designs.
To wit, using wire and dielectrics with differing constants, to apparently super populate the dielectric coupling barrier between primary and secondary coils. I would like to find a way to look at these super population events, if indeed that is what they are, outside of the coil. This is an E Field "circuit" I am discussing here, though between every electrostatic moment those same electron "positions" flow as current, until the next electrostatic moment, that allows for a vector change in the field event.
For the EnABL patterns, I agree. I am using controlled perturbation and a "shock wave" approach to loft the area of energy transform from transverse wave to compression, up off of the usual boundary layer constraints, with a controlled turbulence that disallows reflection, diffraction and their attendant standing waves, including Raleigh waves.
Definitely not damping them out however. More like flinging the energy out of the boundary layer, in an area above the portion of the boundary layer where the typical transform process occurs. A layer, perhaps, where there is much less reason for that energy to transform in a less than coherent fashion.
Bud
Old 6th August 2007, 08:01 AM   #89
Nordic is offline Nordic  South Africa
Nordic's Avatar
Would someone please draw these damn things, and where they connect...
Just read through 4 pages again without forming any clear idea on how it looks or connects....
Old 6th August 2007, 08:28 AM   #90
Nanook's Avatar
Default Non loudspeaker thoughts...
Bud:
I hadn't considered the non loudspeaker connetions yet, I am trying to understand one thing at a time
I do however recall the idea of connecting all componnents in a system together with wire so that a common "ground " could be utilised. I am talking about chassis grounds in relation to one another, so that floating grounds and the potential differences were reduced or removed.
so I think I need a little time to digest the non loudspeaker connections, and a possible explaination.
Electrons on Parade Rodeodave Tubes / Valves 0 25th March 2009 07:16 PM
Electrons on Parade HEADinaJAR Tubes / Valves 0 25th March 2009 10:21 AM
Page generated in 0.13509 seconds (83.42% PHP - 16.58% MySQL) with 11 queries
