| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#491 | |
#492 |
Personally, I think that the "number believers" are:
1) people who have poor hearing, or who do not trust their ears (which amounts to the same thing) and / or 2) people who get "turned on" by the numbers themselves, rather than music - sort of like CPU overclocking maniacs. To me hearing is all the proof I need; I have absolute hearing, I can play a few different instruments, I have been going to philharmonic performances since I was a kid - I have every reason to trust my ears, and I do. And what I hear often goes completely against the so called scientific knowledge - which, to me only proves that a lot of what we call science now, will be called superstition in a hundred years. My point is, current science cannot accurately and exhaustively describe all the processes that take place in the sound reproduction and perception, which means that science alone can only take us so far - beyond that, the only way to improve is through experimentation and listening. Which, rather perversely means that a TRULY scientific approach would take into account all the non-explainable phenomena - so long as they are audible and reproducible.
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#493 |
I have always been pleased by the following report from Dave Davenport.
Groundside Electrons Marce you are spot on for your comments about NOT connecting these things to a digital ground. My now retired cheap Sony CD player lost it's ability to sync up with an external DAC for Red Book, within seconds of my first and only experiment with digital grounds and loops of Type 2 Litz wire. It's still retired for this reason! Which brings me to another question. Can anyone point to testing of type 2 Litz wire as a stub antenna? Or, any other form of antenna for that matter? I am using it as unshielded interconnect cable and do not appear to have any audible pickup from airborne EMF, where an unshjelded stranded non Litz cable (both 2 meters in length) is quite a good antenna. Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
#494 |
Uncle Leon, yawn, that is the usual reply, and not unexpected.
Cbdb, I have one of the first sets of enabled drivers (FE207's were in a Curvy Chang, now in an OB with 2 15" per side) done by Dave on Planet 10, so though it may surprise the only need ears fraternity, I am open to some insanity and will experiment and try new and esoteric ideas. I have also enjoyed the discussions these ideas on Bud's various threads, which by their very nature seem to invite very polarised views. As to hearing, it was evidence and pointers for research put forth on this site that made me question not how good human hearing is; but how it can be affected by so many things, and as stated regarding the psychoacoustics', not only physical but mentally. Also my youngest son has neurological deafness that is more prominent in the higher frequencies, so I have spent the last 12 years taking him to audiologists and speech therapy, and surprisingly have learnt a little of these people regarding hearing. And finally I work for a company (Tactical Communications and Surveillance) that actually uses both measurements and listening tests (though run in a viable way, all participants' have their hearing tested so that there is a metric against what they hear, all done blind, multiple participants) these being modified rhyme tests and similar. And finally age, as the augurs' of hear all and design by ears only get older, their measuring equipment starts to deteriorate, and is much harder to replace than a good scope. For the record I was brought up in a very musical household, my mother was a trombonist with Ivy Benson Dance Band, my father was into opera in a big way. dorothy england I had piano lessons from a very early age (and had no choice when it came to practicing every day), also played trombone (in the local Brass Band) and played bass guitar for a number of years in a band until work and the realities of life took over. So probably have some idea what music is, and using my ears. Why have I spat my dummy out... Because I am fed up of being told, my hearing is defective, my system is not up to it etc etc, because I question beliefs and ask for some empirical data (Captain Capricorn syndrome), other than I can hear the difference...We need both measurements and listening impressions. As to cant be measured (another repeated elucidation), in the electrical environment, I would speculate that any change that can produce and audible difference can be measured, get hold of a 13GHz scope and have a look at some wave forms...and before you all get on my case I did use the caveat of an audible difference regarding measurements. And finally when it comes to power supplies and digital design, hard empirical measurements are a necessity, though some of the hypothesises beginning to come out of the ever expanding DIY audio digital design, would be almost hilarious if it wasn't that they promote and influence BAD engineering practice. As I have said before, we are creating a music reproduction system, so should use good engineering practices, we are not creating musical instruments... Anyway rant over, this forum is better than therapy some times... My apologies to Bud for his patience and to any Audiophiles I haven't upset today, keep up the good work, and as to the rest of us Have Fun |
#496 |
| Electrons on Parade | Rodeodave | Tubes / Valves | 0 | 25th March 2009 07:16 PM |
| Electrons on Parade | HEADinaJAR | Tubes / Valves | 0 | 25th March 2009 10:21 AM |
| Page generated in 0.12591 seconds (78.49% PHP - 21.51% MySQL) with 11 queries |
