| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#471 |
This sounds like the perfect thread for me to get involved in. Call it SY bait, if you will. I will lie on the Groundside Electrons Train tracks and make SY attraction noises. It should work.
![]() I'm late to the party, but I'll race to the end ...and hopefully similar as been said already. My two cents: In all, though, to be serious..a good solid ground return path is necessary. Anywhere in a given circuit where there is any withdraw or transposition of current from the system occurs, is where a good ground return should be located. It should be symmetrical and similar to the current use and exit from that given transposition circuit/point. The sum total capacity of the combined grounds should be the same as the current draw from the wall..and should be arranged to have a simple path and treated as carefully as any delicate signal, with regard to coupling, position and dynamic needs. Think of the entire ground path as passing the signal. For in essence, it is. Imagine an audio cable made up of the exact construction of the ground path in the given gear. For in essence, that is exactly what you have. Last edited by KBK; 24th June 2011 at 03:46 AM. |
#472 | |
KBK, my point exactly! Unfortunately this sort of care is not common. SY has been baited by the way. He has a few sets of the commercial Ground Control in various stages of completion. Thinks they are worthless too. But gives me points for sincerity.... Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
#473 | |
This sounds interesting Bud, what did I miss. Sounds like you guys need to look up Eric Dolan. One of the recent experts on ground wave RF 'punching'. (longitudinal wave launch via inductive groundplane punching). The massive inductive dump punches the groundplane and creates a huge longitudinal 'elastic dish' effect and thus the differential results in a longitudinal wave which creates a high amplitude 'normal' wave. Good ole' inductance. Not anything like the textbooks tell you it is. Textbooks are notes for engineers.. and have nothing (who are only allowed to calculate, never postulate or think on theory) to do with the reality of what inductance actually is. Go back to the original theory and explorations... and you'll get the facts of the origins of 'LCR' which tell a whole different story. Last edited by KBK; 25th June 2011 at 04:01 AM. |
#474 |
You didn't miss a thing. That was a description of what a loop of Litz wire resembles, to an EMF. I just wanted to pursue the idea.
As for LCR, well, I design and build audio transformers that have built in passive demagnetization and no hysteresis storage loses, utilize coupling surfaces and dielectric materials in the coil to create an electrostatic circuit and use that circuit to reinforce and focus the antenna event, coupling across the dielectric barriers. I have been to the theories found the first order derivations from them wanting, for anything but low frequency power transform and have wandered off on my own. Ground control, absolutely stable, neutral, unshielded, ultra low loss cables and a process for causing drivers in speakers to actually perform as they theoretically should, have been the result of the wanderings..... and did you mean Eric Dollard?
#475 |
Yes, Eric Dollard. Missed the last name, there. A case of Reading From The Same page, I guess.
#476 |
BudP,
Has Walker Audio paid you for your idea? I just saw they offer for sale: 'Eliminator Directional Antennae'. To quote them (actually an article from The Absolute Sound) "The Eliminator is a pair of high-speed directional antennae made of pure silver wire with pure silver spades at one end of each wire. The wire has been tested for directionality and treated cryogenically with a deep immersion process. By attaching the spade ends to the negative binding posts of an amplifier, users will hear a difference in as little as 30 minutes and will have 90% break-in in 20 hours." I hope I'm not riling up anything here as I've seen you devices for sale commercially but credit was given to you by that particular vendor, but I didn't see your name metion in the article. To be fair though I have not looked on Walker's sight. |
#477 |
Sorry, I should proof read. Pardon my spelling mistakes. ie; your devices, not you devices and your name mentioned, not metion.
#478 |
An old catch - you credit:you're liable; you don't:you're a thief. At least in the minds of the many.
Maybe I too should go read some Stallman again; and while I'm down there, some Torvalds and Lanier... |
#479 |
I first installed 26-inch zip wire loops to negative speaker terminals and I became a believer. Immediately, I thought I heard something different. After listening a while, I sensed there was a deepening in the perceived breadth and width of the sound stage. Vocalist seemed to be well defined in location in a 3D sense.
Based on material I had on hand, I subsequently made a pair of GC loops from (8) 6-inch long loops of 30-guage RS magnet wire. I twisted the strands together, used flux and dipped each end of the loops into a solder pot. I installed the 1/2-inch pieces of shrink wrap appropriately split as prescribed by BudP. I replaced the zip loops with these mag wire loops. Initially, the new mag wire loops were a little bright, but after a about 8-hours of break in I did not detect a major difference in the sound between the two loop topologies. I used 8 loops of the 30-gauge because that cross sectional area was around 18-gauge. I computed this based on the area of BudP's topology. I have since reread what I could find in this thread and others trying to determine if I should use smaller gauge with more strands. Considering the skin effect involved should topologies made up of smaller gauge with more strands be considered over larger gauge and fewer strands? Others have made up loops comprised of large number of strands. Is the number of strands more important than cross sectional area? I plan to make some loops out Teflon clad Cat5 wire. I will be using the cross sectional computations as to the number strands.
Davet |
#480 |
As for the Walker items, if you want to deliberately insert RF signals into your chassis circulating currents and spend money doing it, buy from them.
The Ground Controls use type 2 Litz and the rejection of external EMF fields is extremely efficient. That you can achieve the same audible results when changing from an obvious antenna, the loop of zip cord, to a loop made from wires with as high a proximity rejection of EMF as type 2 Litz, as used in Ground Control, does call Walker's "claims" for operating mechanism into question. Of course, if you cannot hear a difference with any of the wire loops, wires to special rare earth's in a puck, 8 foot long metal ribbons, stub antennas or Ground Control, then all of the verbiage on this thread are called into question and the Walker claims are even more irrelevant. Bud
| Electrons on Parade | Rodeodave | Tubes / Valves | 0 | 25th March 2009 07:16 PM |
| Electrons on Parade | HEADinaJAR | Tubes / Valves | 0 | 25th March 2009 10:21 AM |
