Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Groundside Electrons
Old 29th March 2010, 12:44 PM   #361
theob is offline theob  United States
Default Thanks again Bud!!
I spent my whole weekend re-balancing my system for bass. The dongles made so much of a change (for the better) on my bass I had to change crossover values and filters for the midbass plus positionng of my subwoofer to optimize. Now I get almost a brand new bass performance level...way to the better....more space, better placement of instruments and palpability of the mids.
Thanks again.
Old 30th March 2010, 07:43 AM   #362
marce is offline marce  United Kingdom
Had a look at the grounding in the article!
IMO horrendus, it should be copper pours these days, with (if required) splits to seperate high current areas from low current areas.
Old 20th July 2010, 02:56 AM   #363
BudP is offline BudP  United States
BudP's Avatar
Just to turn up the fire and increase the agony, here is yet another review of the GC'e, though in this case it includes RCA connected loops, in amps and CD players. Such bold heresy!
Welcome to the Stereo Times
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 20th July 2010, 06:09 AM   #364
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Good Fer Ya Bud!!! Congrat's!
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 20th July 2010, 08:03 AM   #365
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Nice one
Old 20th July 2010, 09:15 AM   #366
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
Ground Control...best thing since EnABL!
Old 20th July 2010, 09:57 AM   #367
On Hiatus
SY's Avatar
I had never heard of this publication before. Thanks for the link- clicking around that site ended up being quite entertaining.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th August 2010, 09:58 PM   #368
bcharlow is offline bcharlow  United States
Default Ground Control DIY results so far
So far the quick and dirty method (simple lamp cord loops on speakers) really opened my eyes. I added loops on the speaker outputs from my sub, but could not detect any difference there. Held off on doing the main amp speaker outputs, because it's a pain in the butt to get stuff on and off back there, and didn't want to try it until I had a better DIY built.
Got some real Litz today and followed your recipe today. Will try them all over - at least where I have spades (amp, speakers, sub amp). If that works out, I'll make up some RCAs too.
As to the RCAs:
1) Does it matter if you put them on outputs or inputs on CDP, DAC, other devices?
2) Specifically on the DAC, is the analog output OK for placement?
3) If I understand correctly how to build the RCA version, I just pull or disable the center pin and connect the Litz loops to the barrel, right?
OK, there was one other question regarding the use of the link between L & R negatives on the back of the main amp (and I assume on sub amps, or does this work on other outputs as well?) Is that effectively just a short jumper between the two? Can it be made simply by making it the third part of a spade pair, for example, for the back of my amp?
Thanks for all this great stuff, Bud! Who gives a crap why it works, when it works startlingly well....;=)
Old 20th August 2010, 03:25 AM   #369
Bud, the refined version of the GC (using the proper Litz, etc.) oddly took a few hours to settle down. Compare that to minutes with the quick and dirty; but the sound of the improved version is now better anyway. Have yet to get it onto my amp - mess to reach back there! But this is a damn good tweak. Thank you!
Old 20th September 2010, 03:34 AM   #370
tobes64 is offline tobes64  Australia
tobes64's Avatar
BudP,
I have 2 sets of the spade equipped GC's (standard) on their way to experiment with.
My plan is to put 1 pair on my speakers.
I was wondering, since my stereo power amp has a common PCB/signal ground, whether 1 GC on either one of the negative speaker posts would be sufficient?
That would leave the 2nd GC available to experiment elsewhere - perhaps the ground lug of my preamp.
Thanks for any input - Tobes
Groundside ElectronsHide this!Advertise here!
