Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Groundside Electrons
Old 27th November 2009, 12:16 AM   #311
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Acetone?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th November 2009, 01:13 AM   #312
gootee is offline gootee  United States
Laquer Thinner?
Old 27th November 2009, 01:30 AM   #313
GK is offline GK  Australia
Is that what you guys are sniffing?
Old 27th November 2009, 01:40 AM   #314
Alex from Oz is offline Alex from Oz  Australia
Alex from Oz's Avatar
Originally Posted by Carlp View Post
OK, some time ago I bought a few feet of Litz wire to try this tweek. Built two nice looking red loops per instructions, but then I couldn't figure out how to burn off the enamel to solder the ends together. Any suggestions? My 100 watt soldering gun didn't work (but I didn't try to burn off the enamel on each individual strand). Project died at that stage as I had other projects on the bench. Any suggestions?
G'day Carl.
Soldering irons won't do it properly and it's impractical to burn individual strands.
You need some serious heat to make these properly.
My very dodgy and not recommended approach: folded an old metal spoon into a tube shape using a bench vice and a hammer. It's held firmly in the vice and heated using a hand held propane burner.
** Make sure you cut off the ends of the loops as per Bud's instructions.
When the solder is hot enough, dipping the tail into it burns the enamel off with a considerable puff of smoke.
Safety glasses are mandatory and breathing the smoke is not a good idea either.
I'll try and post some pics tonight.
Alex
Old 27th November 2009, 01:45 AM   #315
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally Posted by Alex from Oz View Post
...and breathing the smoke is not a good idea either.
But that's half the fun...
I just use the flame from the propane torch to burn off the varnish - quick, painless and easy.
NOT that I make these silly things
Old 27th November 2009, 01:56 AM   #316
chrisb is offline chrisb
well, isn't that what solder pots are for?
like my mind, this space intentionally blank
Old 27th November 2009, 02:20 AM   #317
Andrew Eckhardt is offline Andrew Eckhardt  United States
The pros use a solder pot for that. The rest of us cry.
Old 27th November 2009, 04:16 AM   #318
I tried that, but all the cut ends frayed.
I wish I could afford one!
Old 27th November 2009, 08:43 AM   #319
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I scraped each strand's end with a knife before assembly, but that is not a quick way to do it!
Old 27th November 2009, 07:12 PM   #320
BudP is offline BudP  United States
BudP's Avatar
With really fine wire a solder pot is the only way to go. Also try to find some of the Kester alcohol based liquid flux. Using isoprpyl 99.9% pure alky make a weak tea colored solution using a lot more alky than called for in the brochure. Dip the wire ends and right into the solder. The alky will ablate the insulation and the wires down inside of the packet will be as clean and well soldered as the outside. Kester will very often provide a free sample of their chemicals if you can represent yourself as a company looking for a solution. Solder pots can be had for less than $100.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Groundside ElectronsHide this!Advertise here!
