Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th May 2007, 03:48 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default Any idea about this mic preamp
http://www.partsexpress.com/pe/showd...number=320-204
Looking for something cheap to work with an electret mic for speaker measurement. I'm not sure if this thread should be here or in the loudspeaker forum but don't want to cross-post.
This kit has been developed as preamp module for a number of audio applications where there is insufficient input signal.
Use as a microphone pre-amplifier or for level correction.
Power required: 10-30VDC / 10mA
Output impedance: 1Kohm
Adjustable output level: max. 40dB
Frequency range : 20Hz to 20KHz ± 3dB
Max. input signal : 40mV
PCB dimensions: 1.2" x 1.7"
K1803
"Any fool can know. The point is to understand" - Albert Einstein
Old 16th May 2007, 05:53 PM   #2
Minion is offline Minion  Canada
Well that Mic preamp looks pretty cheaply Made pluss it isn"t ballanced and has no Phantom power to Power an electret mic and it has Electrolytic Caps in the signal Path.....
You can probably make one that privides the same quality audio output for cheaper than one you can buy one......
http://www.epanorama.net/pdf_redirec...uits/Micro.GIF
or
http://www.redcircuits.com/Page49.htm
both of these curcuits will probably produse just as good or better audio than the one you posted and could probably be made for a couple Bucks......
Cheers
Old 16th May 2007, 07:55 PM   #3
Here is a good, low cost solution.
http://www.audio-kits.com/page/page/4071313.htm
Old 17th May 2007, 01:51 AM   #4
zobsky's Avatar
Thanks, .. I'll build one of them
Preamp Idea coldcathode Tubes / Valves 22 16th February 2009 10:59 PM
Tube Preamp Idea mattthegamer463 Tubes / Valves 14 8th February 2009 12:56 AM
An UL preamp idea. Shoog Tubes / Valves 15 13th October 2007 06:26 PM
Preamp: General Idea Devil_H@ck Solid State 13 15th January 2004 03:48 PM
Page generated in 0.08426 seconds (70.61% PHP - 29.39% MySQL) with 10 queries
