Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Twin-T Lowpass Filter Analysis
Old 15th May 2007, 04:50 AM   #1
gmikol is offline gmikol  United States
Default Twin-T Lowpass Filter Analysis
Okay--
I've racked my brain trying to figure this one out. I'm trying to figure out how to analyse and design filters of this topology. I understand how the "Twin-T" part of it works, but I can't figure out the interaction between Co and Ra/Rb. And I can't find a text that explains it. I'm getting the results out of a filter design tool, and it doesn't explain how it derives the results.
This is being used as a building block for a higher-order active Cauer-Elliptic filter.
Fc = 747.9366
Q = 0.7164
Fnotch=7557.0414
*Ra=1k
Rb=44.5k
R=2.11k
*C=10n
Co=505n
* = Values I provided to the calculator.
R and C work for the correct notch frequency in a Twin-T topology.
Any help that the experts out there can provide would be appreciated. There is a similar high-pass topology with Co replaced by a resistor, but I haven't even started playing with that.
--Greg
Old 17th May 2007, 02:11 AM   #2
Bump...
Anybody???
--Greg
Old 17th May 2007, 06:24 PM   #3
consort_ee_um is offline consort_ee_um  United Kingdom
The more usual way of doing a T filter is shown here:
http://focus.ti.com/lit/an/slyt235/slyt235.pdf
Not sure why you are interested in Co, are you trying to compensate for the input capacitance of the op-amp? It will be small enough to be ignored in most cases.
Old 17th May 2007, 07:21 PM   #4
consort_ee_um--
Thanks for the link to the App. Note. I found that earlier in my search. But I'm not looking for *just* a notch filter. This topology is a lowpass filter with notch. The circuit I've shown above provides the frequency response attached. Co and Ra/Rb interact to provide the lowpass functionality (everything else is just your basic Twin-T notch), but I can't figure out how they interact and how to derive the values.
--Greg
Old 17th May 2007, 08:16 PM   #5
forr is offline forr  France
forr's Avatar
Hi GMikol,
I suggest you have a look there :
http://www.diyaudio.com/forums/showt...655&highlight=
there is a reference to Bainter's notch filter, I can send you his paper. Just email me.
Twin-T Lowpass Filter AnalysisHide this!Advertise here!
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
First-Order Lowpass Filter with a Cap Taterworks Multi-Way 6 14th October 2007 01:55 PM
Lowpass Filter Layout Wynand Subwoofers 4 1st February 2006 06:06 PM
Lowpass filter design diegot Car Audio 2 19th December 2005 05:00 PM
lowpass filter failure theChris Analogue Source 15 14th April 2003 02:36 PM
Copyright ©1999-2017 diyAudio
