| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everyone!
I need to connect a micro-hifi system to a mono amp, but the micro-hifi only has speakers and headphone out. I took a look at the board and it seems the same DIL package IC (with a heatsink) is connected to both outputs, which leads me to conclude that the IC is some kind of "power" op-amp. The power specs of the hifi is 15W output... I would like to know if I can make a conventional signal mixer with two 10K resistors - either for headphone or speaker out, as I only want to be able use the push-button/IR remote volume control of the hifi system - or will it present a problem with the outputs? Thank you in advance for all the help
"There's something organic about a happy cloud of electrons" - Neutron Bob |
#2 |
A passive mixer made with 10K resistors did the trick. Thank you.
| Kenwood P-T400 - line level output ? | jives11 | Analogue Source | 1 | 2nd October 2008 03:50 PM |
| iPod's line level output? | Dxvideo | Chip Amps | 9 | 26th May 2007 02:41 PM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| Preamp with line level output | linuxenthusiast | Analog Line Level | 5 | 30th July 2006 11:42 AM |
| Line Level / Headphones | M.Joshi | Everything Else | 5 | 21st December 2004 05:32 PM |
| Page generated in 0.07415 seconds (69.26% PHP - 30.74% MySQL) with 10 queries |
