Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th May 2007, 04:27 AM   #21
I_Forgot's Avatar
Originally posted by DragonMaster
In fact I want to look for oscillation in audio circuits, align some FM tuners, and probably in a near future, start playing with Microchip PICmicros (Fortunately, both cards each have an 8-channel logic analyzer module, which means I don't "necessarily" need probes for this task, unless I start to find some trouble).
Logic analyzers, unless they are very fancy/expensive, are good when everything is clocking right. Sometimes you need a scope so you can find clock problems that you can't find with a logic analyzer. When your logic analyzer gives you garbage but the simulator tells you it should all be working, its time to break out the o-scope and start looking for glitches that shouldn't be there.
Always get as much BW as you can afford, and get probes to match. If the probe BW isn't at least as high as the scope, you're wasting capability of the scope.
I_F
Old 10th May 2007, 11:23 AM   #22
The trimmer cap is to match the probe to a particular socket.
So a 200MHz and a 100MHz per card.
Even probes without trimmers should work as the software utility allows to adjust the 'scope to the probe.
Antoine
http://dmsaudio.ca/
Old 10th May 2007, 05:49 PM   #23
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
All x10 probes have a trimmer. Perhaps other people have been luckier, but I've had dicky switches on switchable probes. Worse, you can accidentally switch it to GND, not notice, then waste time looking for your signal...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th May 2007, 07:08 PM   #24
But if you get used to them it might be different.
Antoine
http://dmsaudio.ca/
Old 11th May 2007, 12:02 AM   #25
unclejed613's Avatar
actually you don't need a wideband probe or scope to align fm receivers. you use a frequency modulated rf generator and an rf "sniffer" probe which consists of a pair of low capacitance diodes, a resistor and a couple of 100pf caps in a voltage multiplier arrangement. the output of the probe goes to the scope vertical, and the modulating voltage (sine wave or triangle wave) goes to the rf generator and the scope horizontal input with the scope in "XY" mode. the rf generator should be set up to provide about 200khz deviation. with the probe at the mixer input, you align the rf stages, and with the probe at the detector input you align the if stages. the scope gives you a response curve with the center frequency in the middle, and +/-100 khz at the edges.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 16th May 2007, 06:54 AM   #26
jarthel is offline jarthel  Australia
any chance of providing a link to the auction you won?
thank you.
Old 17th May 2007, 01:06 AM   #27
eBay 330105968878 & 330110203129
one of them fails a self-test so maybe I'll use 1 scope of the two, requiring only 2 probes.
Antoine
http://dmsaudio.ca/
Probes for Tektronix oscilloscope T935A ? 00940 Equipment & Tools 1 14th May 2009 06:09 PM
First scope/buying oscilloscope probes rockgardenlove Tubes / Valves 9 7th November 2008 02:59 PM
Oscilloscope Probes for Tube Work tgorham3 Tubes / Valves 2 18th March 2008 09:20 PM
Oscilloscope probes for sound card stef1777 Parts 4 9th May 2007 09:55 PM
Advice on probes for a oscilloscope.... darkmoebius Chip Amps 4 11th February 2004 10:38 PM
Page generated in 0.10006 seconds (77.19% PHP - 22.81% MySQL) with 11 queries
