Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 7th May 2007, 06:05 PM   #1
Tolik is offline Tolik
Tolik's Avatar
Send a message via MSN to Tolik
Default Need help with PIC timer.
Hi All
I wont to build some timer for my UV PCB litebox, but I new to PIC`s design. I found THIS schematic, but it is old, and impossible to get the display unit used here. So can somebody to help me to fit another display unit/controller to this project ?
Old 8th May 2007, 06:12 AM   #2
I_Forgot's Avatar
Sparkfun Electronics sells development boards made by Olimex. Some of them have LCD display modules, so about all you will have to do is write your program.
You can generate code to drive the display using Application Maestro that you can DL free from Microchip.
You can drive lots of current by connecting a low threshold MOSFET to any output pin. One RFP30N06LE will let you switch up to about 30A!
I have doe all these things and they work.
I_F
http://papers.ssrn.com/sol3/Delivery.cfm/SSRN_ID998565_code249137.pdf?abstractid=998565&mir id=1
http://moses.creighton.edu/jrs/2005/2005-11.html
http://www.apa.org/journals/features/psp7761121.pdf
Old 8th May 2007, 06:36 PM   #3
Tolik's Avatar
Thanks for your replay !
My have no problem to get display in my country - Farnell.com or RS.com are providing services in Israel, so I can to get almost any display from them. Problem is - I absolutley new to PIC programming . If you can to help me by answering to some questgions about programm I`ll be very glad.
Old 8th May 2007, 07:10 PM   #4
Tolik's Avatar
Please look at this display. I think it`s seems to be very close to display used in sourse project.
What you think about it ?
You told about software to design the codes for PIC`s, I have latest
version of Altium Designer. Do you know something about abilitys of this program to create codes for PIC16F84 ?
I`m pretty new to digital design, so some of my questions may seems to be stupid
Old 8th May 2007, 07:39 PM   #5
Nordic is offline Nordic
Nordic's Avatar
message me your email address, so I can send you a pdf tutorial, too big to upload here.... about 200k and 100k ....2 files...
Old 8th May 2007, 10:13 PM   #6
Tolik's Avatar
tolik212@gmail.com
Old 9th May 2007, 08:25 PM   #7
Nordic's Avatar
Sent... sorry for the wait... had a hard day...
Some code snippets can be found here...
http://www.piclist.com/techref/io/lcd/pic.htm
In the datasheet for the pic.. you will find info on software you can use to programme and tests in, I think its called MPLAB, nd is free from microchip.com
There are many good tutorials for the basic pic funtions you need... setting up ports as in or output, and reading or writing data to those ports...
Using the info I sent you, you could even run an LCD just with switches... so you learn what need to go in and out...
Old 9th May 2007, 08:52 PM   #8
Tolik's Avatar
Many thank`s Nico
It`s seem`s to be very useful for me. In Future Ill post the pics & discription of this my project.
Are you using any UV device to burn fotoresist coated PCB`s ?
Old 9th May 2007, 09:05 PM   #9
Nordic's Avatar
I made one, but I find just useing the sun is adequate...
On overcast days... just shy of 5 minutes... on sunny days about 3 minutes and 30 seconds is enough...
Old 9th May 2007, 11:02 PM   #10
Tolik's Avatar
Yep. My first fotoresisted PCB was made by sun lite too
Thread Tools
First Timer needs help mgalvez Tubes / Valves 24 17th October 2007 11:34 PM
Help a first timer to select... CJ900RR Tubes / Valves 12 31st January 2006 05:46 AM
Timer Relay Bryan Tubes / Valves 6 15th September 2005 12:45 PM
555 timer latching nickch Parts 1 20th July 2005 09:48 AM
Sleep Timer s0rce Parts 2 8th December 2002 03:51 AM
Page generated in 0.18892694 seconds (85.05% PHP - 14.95% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
