| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can anyone make a recommendation?
Need to trigger 120vac (no more than 6amp loads) with 12 or 24vdc, and have the OFF delay by up to 60 seconds. The closest I could get out of Digi-key is two units combined for over 100 dollars. I have found relay off-delay timers on ebay for less than ten bucks. But I'm not familair enough with relays to know what to look for. For instance, used in conjunction with a std 24vdc/120vac relay, would this be fine? http://cgi.ebay.com/SQUARE-D-9050-JC...ayphotohosting This next one seems perfect 3 to 300 seconds. 24vdc in, 120vac out. Am I on the right track? http://cgi.ebay.com/New-NIB-ATC-Time...QQcmdZViewItem There are many "off delay" relays available, but I notice that some off these are only "egg timers" with terminals - for manually delaying time off with a knob, like on a coffee machine. I need a timer/relay that will automatically continue to deliver 120vac for as long as a minute after the 24vdc signal is switched off. thanks for any advice. |
#2 |
a standard mains relay with low voltage coil powered from the mains side would do. Then put in a 555 timer to monitor the on/off signal and keep the relay closed until the timer goes off.
regards Andrew T. |
#3 |
Was just going to say, you need $2 worth of components to make one...
#4 |
If you like the old look the Amperite relay/delay tubes are very cool. they can switch 6V up to 115V and come with normally open/closed as well as different time delay settings. Ebay sells them as well as Tubes and More, AZ, cheap too. I think Amperite also makes ss as well. This pdf shows how to order/find the correct one.
http://www.amperite.com/Uploads/g.PDF |
#5 |
I don't have very much depth in electronic skills (at least compared to what is typical here at diyaudio). I create a lot of things, but my projects are by necessity more macro engineered than micro - a variable (off) time 24vdc/120vac relay is pretty much a "black box" utility for me.
The second link that I posted would be just perfect, except that upon closer examination, it's only 120vac input. Now I can stick a std 12/120 relay upstream of this, but now It's getting messily complicated and expensive again. Any chance that there is a circuit diagram on the net for a small component-count method of doing this? I'd like to make it knob adjustable to about two minutes ideally. Thanks so much for the suggestions. |
#6 |
diyAudio Moderator Emeritus
Check out page 9 of the TI 555 timer datasheet.
The values of Ra and the capacitor determine the time constant and thus the delay. http://focus.ti.com/lit/ds/symlink/na555.pdf
Brian |
#7 |
CD4541
This ic is intended for this application in particular. It has a auto power-on reset, and also needs small cap. Gajanan Phadte |
#8 |
I found it!!
(..and that was a bumper sticker in the seventies -- man I wish the rapture would just hurry up and deliver some of these idiots) http://cgi.ebay.com/DAYTON-6A855-TIM...QQcmdZViewItem (and he didn't even try to bend me over the couch for the shipping costs!) I did say that this was "black box" engineering for me. And this is a heck of a black box for anyone interested in monkeying with this sort of thing. Use the right little SS relay and you could combine this with just about anything to control a circuit. Anyway, thanks for the help here. |
| B+ time delay relay | cbutterworth | Tubes / Valves | 24 | 31st August 2011 01:53 PM |
| Suitable relay for delay cicuit | Nuuk | Chip Amps | 61 | 11th January 2009 02:47 PM |
| Relay delay | Ted205 | Chip Amps | 16 | 24th September 2008 06:44 PM |
| on/off thump - use Time Delay Relay ? | redrabbit | Everything Else | 0 | 29th June 2008 03:01 AM |
| Time Delay Relay Tubes | cadman | Tubes / Valves | 8 | 17th December 2002 05:25 AM |
| Page generated in 0.10168 seconds (81.15% PHP - 18.85% MySQL) with 10 queries |
