Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
vishay caps, anyone use them
Old 3rd May 2007, 02:07 PM   #1
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default vishay caps, anyone use them
i look in farnell, newark and digikey, they supply this caps
anyone use them in they audio project ?
can you describe compare with panasonic, vishay or aerofox or nichicon ?
is it ok if i use them for psu board ?
tell me please
Old 3rd May 2007, 09:11 PM   #2
Geek is offline Geek
Geek's Avatar
I'll take Vishay over the others you mentioned anyday.
As for my opinion of sound, less "cloggy" than most other off-the-shelf types.
Cheers!
Old 4th May 2007, 10:47 AM   #3
Pocoyo's Avatar
Default anyone info ?
thank u geek
is anyone have more info for me ?
Old 4th May 2007, 10:56 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
Yeah, the low ESR Vishays rock....!!!
Old 4th May 2007, 11:21 AM   #5
Pocoyo's Avatar
Default cloogy ?
sorry for my bad english
cloggy ? i look in dictionary but .... do not understand
if we compare with BG Std assume same size [1000uF 50V]
wich one better?
pls pls i cant try them maybe i just need info from all my friend
Old 4th May 2007, 11:40 AM   #6
Tweeker is offline Tweeker  United States
Context might help. My drain is clogged. The water is not flowing down it as it should. It leaks too. Or in the caps case, I guess the electricity is not flowing ideally.
Congested, stuffy.
Be sure your foil hat has a good low impedance ground.
Old 4th May 2007, 12:20 PM   #7
Geek's Avatar
Originally posted by Tweeker
Congested, stuffy.
Dat's da verd!
Old 5th May 2007, 02:56 AM   #8
Pocoyo's Avatar
Default i see
hii
i know what you mean
maybe that not vishay
how about panasonis, aerofox and nichicon ?
anyone suggested
Old 5th May 2007, 05:02 AM   #9
Geek's Avatar
I've used Panasonic and Nichicon electolytics in the power supply. Panasonics have low ESR (no poly bypass needed).
Old 5th May 2007, 10:18 AM   #10
Nordic's Avatar
Jeff he said it sounds LESS cloggy...
I agree wonderful quality caps.
vishay caps, anyone use themHide this!Advertise here!
WTB - Vishay MKP1837 0.01 mF Caps slhijb Swap Meet 5 11th January 2009 04:12 PM
Vishay caps rinx Multi-Way 14 11th June 2008 02:35 AM
Black gate caps and vishay bulk foil resistors biovizier Parts 1 21st June 2005 04:20 PM
Vishay now in Oz Jye Parts 1 9th December 2004 12:08 AM
Vishay/Roederstein 2200uF/63V 105C caps for sale/trade Andypairo Swap Meet 2 18th August 2004 04:09 PM
Copyright ©1999-2017 diyAudio
