Philips 753 Toslink out question - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th January 2003, 05:55 PM   #1
Wombat is offline Wombat  Germany
Wombat's Avatar
Default Philips 753 Toslink out question
I have a Philips 753 around here and i´d like to
add the toslink exit. The layout should be similar
to the Philips 723. Does anybody have a shematics
or another idea how this can be done?
If time permits - stuff some parsley in your ears and listen how it grows!
Old 19th January 2003, 07:40 PM   #2
Tube_Dude's Avatar
Default TOSLINK
Hi Wombat!
You can use the Toshiba TOTX173...see the data sheet
http://www.toshiba.com/taec/componen...et/TOTX173.pdf
the input terminal 4 must be conected to the pin 14 of the SAA7220
http://members.xoom.virgilio.it/hi_fi/index.htm
Hope it help!
regards
Jorge Santos
Old 19th January 2003, 07:54 PM   #3
Wombat's Avatar
Thanks Tube_Dude!
Should be no problem.
A part list for the given design would be more
welcome but if it doesn´t come i will build it
the easy way with the transmitter directly to the
SAA.
Question about bass driver in combination with Philips 9710? bezobraznia Multi-Way 3 13th December 2008 07:15 AM
philips cd pro-2m noob question fergs1 Digital Source 1 13th February 2006 05:37 PM
Philips 963SA mods: AD1955 question Guunther Digital Source 0 21st April 2005 07:58 PM
Toslink to DAC sugano Digital Source 3 17th June 2003 09:59 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
