Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st May 2007, 03:58 AM   #1
Default Slow Turn On Led
I'm doing a lil souvenir and i need to make a LED turn on and off slowly, but i can't find any schematics to do that...any ideas? i can turn it off slowly by using an electrolytic cap but it' not too nice so i was wondering if there's an ic to do that?
Old 1st May 2007, 04:26 AM   #2
OzMikeH is offline OzMikeH  Australia
two ways:
Pulse width modulation.
or
use a filament lamp instead.
Old 1st May 2007, 06:48 AM   #3
u need a triangle wave generator.
Gajanan Phadte
Old 1st May 2007, 08:31 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
there is a 1.5v led driver ic, it is obsolete, but stil available...
Will have a look for the number... Also there is a 2 transistor led flasher circuit I have been playing with, trying to miniaturise for a friend, which flashes the way you want ---- when the battery gets flat...
try Hi brightness LED wich requires more current.... it will allready slow down things....
Old 1st May 2007, 08:42 AM   #5
Nordic's Avatar
LM3909
http://www.redcircuits.com//Page87.htm
Old 1st May 2007, 11:13 PM   #6
cpemma is offline cpemma  United Kingdom
I'm not quite clear with your requirement - is this a fancy power indicator that fades in (or out) just once on power-up (or down) or a novelty item doing a continuous cycle?
For the former, the simple way is two resistors between power and LED with an electrolytic cap (470uF?) to ground from the mid-point. To get an effective fade keep the maximum LED current to about 2mA, so from a 12V supply the two resistors would be about 2.4k each. This always applies when trying to fade LEDs - ignore all supplier "specs" telling you to use 20-30mA and start from an off-peak brightness.
For a continuous throb, see the two here.
Full-turn/partial-turn pots slowpogo Parts 1 12th January 2007 07:40 AM
slow turn on audiofan Solid State 5 2nd November 2006 04:23 PM
help customize "slow turn-on" duration in this circuit (link to schematics inside) jarthel Power Supplies 10 17th August 2006 06:05 PM
Slow turn-on for LM78XX regulators? JojoD818 Solid State 0 15th February 2004 11:16 AM
How can I reduce mechanical turn on and turn off noise? soundNERD Chip Amps 8 28th October 2003 01:43 AM
Page generated in 0.08445 seconds (71.12% PHP - 28.88% MySQL) with 10 queries
