Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th April 2007, 04:03 AM   #1
Default Panasonic FM series capacitor - anyone have opinion?
Hello,
I have read that the Panasonic FM series is supposed to be superior to the Pana FC series.
Has anyone tried the FM? or have any feedback?
Kevin
Old 30th April 2007, 10:52 AM   #2
EchoWars's Avatar
I use them all the time. They are not really available in values that would be used for signal path duties, but rather for filtering and bypass (from Digikey, anyway). When I sit down to order caps, if the voltage I need is 50V or lower, I check to see if I can get the FM cap instead of the FC cap. If it is not available, I get the FC, or go look at the Nichicon HE (their equivalent of the Panasonic FM).
Old 2nd May 2007, 09:20 PM   #3
BrianDonegan's Avatar
I second that. FM were possible, FC otherwise. They are generally cheaper to boot. The HE, though it is the cross ref for the FM, doesn't match the low ESR of the FM.
Twisted Pear Audio
Old 6th November 2008, 09:06 PM   #4
Some people claim that Panasonic FJ are better in ESR and ripple current than FM.
Regards.
Old 7th November 2008, 07:53 AM   #5
gurusan is offline gurusan  United States
Send a message via MSN to gurusan
I just purchased some 470uF panasonic FM caps to use on a new starving student millet headphone amp build.
I will use Panasonic FC for power caps and Panasonic FM for output caps bypassed with Wima MKP10 .33uF
My current starving student amp is using nichicon pw power caps and Nichicon Muse ES 330uF output caps bypassed with Wima MKP10 .33uF.
and Echowars, can you explain more why would you not use them for signal path duties? I am quite new at all this DIY stuff (I've built a cmoy, a starving student, and as I mentioned I'm about to build another starving student).
On another note, I've also heard the FJ caps are a bit better than the FM, but I can't seem to find anywhere that stocks them.
Old 8th November 2008, 09:12 AM   #6
On another note, I've also heard the FJ caps are a bit better than the FM, but I can't seem to find anywhere that stocks them. [/B][/QUOTE]
You can find them on eBay only.
Also I can't find them anywhere else.
Seems like Panasonic don't want to introduce them. Only on US website there are some links, but in catalog they are lacking.
Old 8th November 2008, 09:40 AM   #7
yeah you can find them on ebay, but I can't seem to find anywhere that sells over a 16V rating.
Old 11th November 2008, 09:50 AM   #8
I have found on some Chinese source a datasheet (or smth like that) of Pan FJ series. But I can't attach it (pdf-512Kb). Seems like there is a limitation of DIYAudio.
For 50V ratings it's not a great choice for capacitance values. From 100uF to 330uF only.
Old 11th November 2008, 12:01 PM   #9
The fact that Panasonic does not list the FJ series, even in their discontinued products list, means that they are likely quite old. Not a great thing for electrolytic caps. Be sure you properly condition them before use.
Twisted Pear Audio
Old 11th November 2008, 02:50 PM   #10
Recently, I've asked Panasonic to send me a datasheet of FJ caps, but they didn't answer me.
BrianDonegan, seems you are right. The engineering draft of FJ caps which I've found is dated on 23 May 2002.
BTW, I just read your signature. It's wonderful. I suppose you have a same friend.
Regards.
FS: Panasonic FC Series Electrolytic Caps & Others xtaltech Swap Meet 15 15th April 2009 02:03 PM
Panasonic FM series 1500u 35V zxcxz Swap Meet 2 5th March 2009 05:30 AM
FS:PANASONIC FM series very low impedance !!! ANALOG GUY Swap Meet 2 11th July 2007 07:42 AM
Where can I find Panasonic P series in Europe? Zodiac Parts 8 1st July 2004 10:45 PM
Panasonic THA series Electrolytics Mark A. Gulbrandsen Pass Labs 0 15th November 2003 02:19 AM
Page generated in 0.09537 seconds (83.19% PHP - 16.81% MySQL) with 11 queries
