Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th April 2007, 02:39 PM   #1
dome406 is offline dome406  United Kingdom
Question 12V to 5V
This is a rather trivial question, if I have 12V from a power supply how can I drop this to 5V. The current drawn is going to be 0.5A so potential diveder not practial ?. I thought you could use a 5V voltage regulator which I tried (L78M05) however get an output of 7V.
Will
Old 29th April 2007, 02:53 PM   #2
Sonusthree's Avatar
It's a little strange that you had 7 volts. How was it connected? Did you try another reg in cas that one was faulty?
You say that you need 500mA but the L78M05 is only rated at that. You should probably try a 1/1.5/2 amp 5 volt reg instead.
http://www.maplin.co.uk/search.aspx?...enu=y&doy=29m4
Old 29th April 2007, 03:03 PM   #3
Unfortunatley I only ordered one it was connected as in the datasheet. Its for a project which has to be handed in on friday and i was doubting if what i had done was correct. Will have another look at it when go back.
Thanks very much
Old 29th April 2007, 08:37 PM   #4
Minion is offline Minion  Canada
When you tested the Voltage of the 7805 regulator dwas there a Load on the Supply??
I believe that proper regulation can only be accomplished with these regulators if there is a Minimal Load on the Regulator, So maybe try putting a LED or a resistor on the 5v supply and then test the Voltage and it should be closer to the correct 5v.....
Cheers
PS the LM117/217/317 Positive regulators are adjustable so you could Dial in the correct Voltage useing a trim pot....
Old 29th April 2007, 08:55 PM   #5
cpemma is offline cpemma  United Kingdom
It's probably testing without a load, the 5V±0.25V output is only guaranteed with loads over 5mA and multimeters are way less than that.
Old 29th April 2007, 09:31 PM   #6
XEAGLEKEEPER's Avatar
http://www.sound.westhost.com/project05a.htm
This may be of some help.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 30th April 2007, 12:28 AM   #7
I_Forgot's Avatar
I've never seen one that puts out anything more than maybe 100mV away from spec'd value under no-load to full-load conditions. Those ICs have an internal reference. I'm betting it was connected wrong.
I_F
Old 30th April 2007, 03:09 PM   #8
Another possibility. From here
A while back I hooked up a 5V regulator using long wires and no capacitors and got 10V out of it! Adding the output capacitor fixed the problem instantly. When I say 10V I don't necessarily mean DC. I assume the regulator was oscillating like crazy.
So when you say "It was connected as in the datasheet" you mean including the recommended capacitors?
A 317 will usually regulate fine with no load, as the typical 240R pot divider resistor between Output and Adjust pins gives a 1.25/240 = 5mA loading.
Old 2nd May 2007, 07:47 AM   #9
TwoSpoons's Avatar
12 - 5 = 7. Its just possible it was working fine and you connected your meter to the wrong points.
Page generated in 0.09236 seconds (87.29% PHP - 12.71% MySQL) with 9 queries
