Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th April 2007, 04:43 PM   #1
dclapp is offline dclapp  United States
Question Help identifying transformer?
This is my first post, so please be kind!
I've attached an image of a transformer I took from a '80's Pioneer SX-50 stereo receiver.
I'd like to use this for a chip-amp power supply. But I don't have a clue about "what it is" in terms of which lead does what and what the power (VA or whatever) is.
I wrote to the manufacturer in Malaysia, but never heard back.
Can anyone here help me with this? And...would it be a good choice for a homebrew power supply?
Thanks in advance!
Doug Clapp
Old 28th April 2007, 06:58 PM   #2
FastEddy's Avatar
If working and still installed in the original Pioneer chassis, then CareFully measure the AC voltage on the trio of connections (background of the picture). My best guess: primary winding (pair) is in the foreground of the picture, secondary winding trio ~/0/~ (center tap & two output windings) is in back ...
Also, what is the size of the fuse/breaker in the old Pioneer chassis? This will give you a clue as to the total Volt/Amp (VA) of the transformer. [Example: 3 amp fuse = 120 VAC X 3 = 360 VA divided by 0.6 (60%) = safe bet as to usable power (volt/amp VA)] ... another clue to this is of course the power rating (watts per channel) of the Pioneer ...
Total less than 25 watts = good resource for op-amp / pre-amp circuit power ... 50 watts of more = good resource for chip-amp / power amp ... in between, might be used for tube pre-amp or even smaller tube power amp .... maybe.
Old 2nd May 2007, 01:28 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Bando,great quality!!!!!!!!!!
Identifying output transformer leads bereanbill Tubes / Valves 7 24th April 2009 02:27 AM
Help identifying Output transformer georgepw Parts 2 4th March 2009 08:02 AM
Help Identifying Transformer SLT5M329 Redshift187 Parts 1 18th August 2008 12:04 PM
Help identifying IC mtl777 Parts 4 17th May 2008 09:10 PM
Identifying weird signal transformer Klimon Tubes / Valves 4 28th August 2006 12:50 PM
Page generated in 0.08184 seconds (72.62% PHP - 27.38% MySQL) with 11 queries
