Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th January 2003, 05:34 PM   #1
cm961 is offline cm961  Canada
cm961's Avatar
Unhappy Thermal Protection Circuit
Hi everyone,
I'm trying to understand this amp's thermal protection scheme. I've drawn out the schematic of it and it doesn't make sense to me.
The fused neutral line goes through 2 thermal switches (1 for each channel) (normally closed) in series and then connects to the live live. In paralelle with these two thermal switches is an LED w/ resistor. This is the temp. indicator LED.
So the basic operation would be, under normal temperature the switches are closed and the LED is off. On overheat, the switches open and the LED gets current. The things I don't understand are the following: If the switches are closed all the time, it shorts the live to the neutral and the fuse blows. If the switches are open (overheat condition) the LED comes on, but how does that protect the amp?
I can draw a schematic if I'm being too confusing. Any help greatly appreciate, I'm sure I'll get this amp working soon!
Pete
Old 20th January 2003, 08:20 AM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Pete,
You're right: You are being confusing
Try posting a schematic. Draw it in MS paint if necessary. Then I'm sure you'll get some suggestions.
Old 21st January 2003, 04:19 AM   #3
cm961's Avatar
Thanks John,
I figured it out. It was a really stupid mistake made by me. I was using my continuity tester to trace the circuit, and what I didn't figure was that the transformer coils were in series with the circuit, yet causing basically no voltage drop. So I'll explain the circuit, more clear this time (I hope).
The normally closed thermal switches are in paraelle with the LED indicator + resistor. All this is in series with the transformer. So what happens is that the resistor and LED are normally shorted. If one of the switches opens, the current flows through the resistor and LED. The resistor is 10k, and the impedance of the transformer at DC is very little, so the resistor drops about all the voltage. The LED gets some too and turns on, and since the resistor and LED are dropping all the voltage, the transformer coils get none and thus the power supply is effectively disabled.
I've made a few really amateurish mistakes on this amp, but I'm happy to annouce that I've got both channels functioning now. One has only 4 of 6 transistors hooked up, but I just have to order more and I'll solve that.
Thanks to everyone on diyaudio, you've all been very helpful.
Pete
GFA 535 II thermal protection led lit kheper Solid State 1 23rd June 2009 04:01 AM
Thermal/Speaker Protection tumler Solid State 0 27th January 2008 09:17 PM
after 3 yrs. thermal protection kicks in on 2 of 4 ch. slicey Car Audio 5 10th September 2005 10:47 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
OPA541 w/ or w/o thermal protection? JojoD818 Chip Amps 17 4th January 2004 11:15 AM
Page generated in 0.08182 seconds (70.31% PHP - 29.69% MySQL) with 10 queries
