Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st April 2007, 10:13 PM   #1
Default Is there a better replacement for the NJM4565 op amp ic
Hi
Is there a direct (but much better) replacement ic, with very much lower distortion, to replace the NJM4565 op amp ic (with same pinout) ?
Thank
Gaetan
Old 23rd April 2007, 02:09 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
NJM4580.
Old 24th April 2007, 06:03 PM   #3
Hi
How about the TLE2037 op amp ?
Any one try it, how it sound ?
Thank
Gaetan
Old 24th April 2007, 08:55 PM   #4
Juergen Knoop's Avatar
hi,
it is not a replacement
regards
Old 24th April 2007, 09:49 PM   #5
Minion is offline Minion  Canada
Any standard Bipolar Opamp thould work as a replacement Like even the NE5532 would be better (Much faster and Lower noise)...
That is if your 4565 is in the Dip8 package.....
Cheers
Old 25th April 2007, 02:18 AM   #6
Cheers
Hi
No, my 4565 are in SOIC package. It's the output op amp of my Ensoniq audio pci soundcard.
And I have some 5532 in Dip 8 package.
Thank
Gaetan
Old 25th April 2007, 03:58 AM   #7
Well the NE5532 come in SOIC also....
Cheers
Old 25th April 2007, 10:44 PM   #8
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Why don´t you try the real ones,Lm4562 SOIC.
Regards Åke
Old 25th April 2007, 10:55 PM   #9
Hi
Because I want to try a much better IC
Thank
Gaetan
Old 25th April 2007, 11:05 PM   #10
Fenris is offline Fenris  United States
The LM4562 is an IC...and it doesn't get much better.
Listen to the music through the stereo, not the stereo through the music.
Replacement LED DreadPirate Parts 11 14th November 2009 04:45 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 02:33 PM
Another cap replacement: uF changes.. cuibono Tubes / Valves 8 6th November 2007 08:06 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 04:32 AM
Replacement for 5R4 Ralph Tubes / Valves 8 16th December 2003 10:02 AM
Page generated in 0.10316 seconds (77.00% PHP - 23.00% MySQL) with 10 queries
