| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
here's the datasheet: http://www.jaycar.com.au/products_uploaded/SY-4080.pdf
here's the circuit: http://www.diyaudio.com/forums/attac...amp=1156387690 The "trigger control" of the relay is connected to a simple ne555 circuit. After initial turn on, pin 3 (of the ne555) is high. After 11secs, it goes low. I have tested the ne555 circuit 15 minutes ago using an LED between pins 8 and 3 (of the ne555) and the LED lights up after 11secs. I believe this is the correct behavior. when the amp is turned off, I checked for continuity between pins 1 and 2 (of the relay) and there is no connection. Pin 1 is connected to the "line" wire of the AC mains. I connected the red wire of the VOM to pin2 (of the relay) and the other lead to neutral wire of the AC mains. Obviously there is no voltage when the AC switch is off. BUT immediately after turning it on, the VOM reading goes to 240VAC. I believe I should only detect 240VAC on pin2 if there is enough load (datasheet says minimum 24V load) and ONLY after 11secs has passed. I believe a VOM shouldn't present enough load on the relay to produce an output. AND even if the VOM does present at least 24V load, I should only get 240VAC after 11 secs. any ideas/suggestions? thank you for the help |
| Relay | hugobors | Parts | 6 | 21st February 2006 10:20 AM |
| Looking for the best relay | carlmart | Solid State | 15 | 19th August 2005 12:06 AM |
| Can I use a SIL relay ? | Ryssen | Solid State | 8 | 29th December 2003 10:45 PM |
| Help with relay | ppereira | Solid State | 14 | 21st June 2003 08:10 AM |
| Relay or not relay ? | Yonnat | Pass Labs | 10 | 10th April 2003 07:26 PM |
| Page generated in 0.05209 seconds (79.00% PHP - 21.00% MySQL) with 10 queries |
