Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st April 2007, 04:06 PM   #1
Default step attenuator conundrum
Here's a challenge for you. I have acquired 3 rotary switches, each with 3 wafers and 16 switch positions. I want to build a volume control for my Gainclone. I would like the quality to be as good as possible, ie, signal passing through as few resistors and soldered joints as possible at any one time. I would also like it to have a sensitivity of 1dB over a range of 60dB or so as my amp needs to cope with varying sources. I'm not concerned about how many resistors I will need to purchase or how fiddly it would be to construct.
Does anybody have any idea how I might do this? I was thinking of using one switch for a central volume control and using the other two each as a trim for the L & R channels in a similar way to the kit you can buy from tubecad.com
( see http://www.tubecad.com/Three-Switch_...nuator_PCB.pdf )
Any comments, suggestions or alternative ideas?
Old 22nd April 2007, 09:49 AM   #2
Mailliw is offline Mailliw  Canada
Shout out from Halifax!
60 positions is a little excessive isn't it? Seems like a lot of work, why not go with the kit?
Old 22nd April 2007, 11:11 PM   #3
I_Forgot's Avatar
A challenge indeed!
How do you propose to get 60- 1 dB steps from a switch with 18 positions?
If you need such fine control AND some L/R balance capability, use an attenuator chip controlled by a uC. Accurate channel matching, small steps and lots of them, remote control capability... What more could you want?
I_F
Old 23rd April 2007, 11:01 PM   #4
Hi Tl5,
that glassware two stage attenuator looks pretty good in the hand.
Something they forgot to mention.
The second stage attenuator should use an impedance about power amp Zin/10.
The preceeding attenuator stage should be second stage Z/10.
The source should therefore be about Power amp Zin/1000.
The closer you push these matching impedances the more inaccurate the 36 steps becomes in the two stage attenuator.
Even so, it's a clever way to reduce the number of resistors and solder joints on the way thro' and still incorporate a fine balance control
regards Andrew T.
Old 7th May 2007, 03:47 PM   #5
thanks for your comments everyone. Still haven't decided what I'm going to do but the input was useful.
Old 7th May 2007, 04:40 PM   #6
FastEddy's Avatar
The Bottlehead folks make a more modest step attenuator, 7 or 8 position. They offer them as suppliments or replacements for their ForePlay tube pre-amp kit ( http://www.bottlehead.com/et/parts/parts.htm ... 2/3rds down the page ).
" ... For use in active circuits the basic 15K series design is re-implemented as a shunt attenuator, often regarded as the most transparent sounding attenuator configuration, putting only one "padding" resistor in the signal path. This additional padding resistor may be chosen from among four values included with the kit, to give the nominal 19dB gain of the original Foreplay preamp circuit (with Anticipation upgrade) a more flexible range of gain. You can choose from 9 db (close to being an industry standard), 3dB, -3dB or -12dB maximum overall gain with the change of one resistor. ..." ... & low cost @ US$40 (for 2)+ shipping ... and they really are quiet.
24 Step Attenuator poynton Parts 1 9th January 2008 08:26 AM
23 step attenuator tryonziess Chip Amps 2 21st May 2007 01:33 PM
12 step 10k attenuator problem vdi_nenna Everything Else 2 26th July 2005 08:10 PM
DIY 40 step attenuator, anyone interested in such??? Magura Parts 64 20th August 2004 04:25 AM
Page generated in 0.10343 seconds (76.79% PHP - 23.21% MySQL) with 10 queries
